Anyone have a source for these?
I see them on Primus' website but they are out of stock.
10-32 thread, 1.5" total length, 1.0 pin length.
Used on my 94 VD front cover.
Attachment 76867
Attachment 76867
had a hard time finding them myself. So I made some.
Very Clever
I've made 'em out of round stock with a threaded hole in the bottom.
McMaster has a selection: https://www.mcmaster.com/#alignment-pins/=1bjl20y
they are pretty hard, might need to anneal them if possible or use cobalt drills and taps.
Yeah, been looking through all those.
The best thing I came up with was a shoulder screw and just trim down the head:
https://www.mcmaster.com/#91259a174/=1bjlttw
but the thread is too short to work. Hate when that happens...
I have a few around if you’re not in a rush. I’ll dig em up.
I actually like xmazda’s solution better, though. I’d use a round head cap screw instead of button head. Either way, I like that it allows for easy installation without a pliers/marring the pins.
Okay. Between Cade and Scott's suggestions:
https://www.mcmaster.com/#92510a569/=1bjmee5
plus
1.5" screw.....
https://www.mcmaster.com/#91306a277/=1bjmfpq
Done @ like $2 ea
Try searching for hood alignment pins
Revised version. The head on the screw above it wider than the spacer. And 1" is a little long.
So, 7/8" spacer:
https://www.mcmaster.com/#92510a568/=1bjxukb
and a screw with a smaller head - not button....
https://www.mcmaster.com/#92220a178/=1bjxuzk
What diameter is the body???
Google "aluminum round standoff" . Look for threaded 10-24 or 10-32. mount with button head from back side instead of nut.
john f
