Page 1 of 2 12 LastLast
Results 1 to 40 of 52
    Albany, NY
    Liked: 238
    Default Question re CV Joint Balls
    This might be a bit remedial but I've never actually had a CV joint apart before. I just disassembled one of the Lobros in my sportsracer and the balls look like they might have some very mild pitting. However they feel smooth when you rub them with a finger tip.
    Don't know how long these CV's have been in use but they are all dated 1998.
    If you have a moment and some expertise, please take a look at the photo and offer an opinion.
    Liked: 931
    How do the races look. If they are pitted as well I definitely would replace it. Having had one fail, it is no picnic to thrash to replace it at the track.
    Lucky for me it happened in a straight line not a corner.
    Hartford, WI
    Liked: 210
    Default Also....
    Make sure there are no hairline cracks propagating out of the radiused corners of the cage "windows" that the balls are retained in. 10x loupe magnification will assist with this.
    Albany, NY
    Liked: 238
    Thank you guys.
    Pittsboro IN
    Liked: 282
    It's junk. Replace it now and save some grief when it fails at the most inopportune time.
    Contributing Member TeamFRD's Avatar
    FL, USA
    Liked: 15
    Jim - I just replaced mine, also dated 98. I've left them greasy but can clean them and take some pics to compare if you want.
    BTW GKN (British) bought Lobro (German) sometime since 98.
    PS Race-parts.com treated me fair.
    ~David
    TeamFRD-1988 Van Diemen RF88-1267 FF1600 Solo:CM#99/199 http://yspect8.weebly.com
    Albany, NY
    Liked: 238
    David are you saying they looked the same as mine?
    FL, USA
    Liked: 15
    After I inspected my CVs dated 88, that were far worse than your pic, I choose to replace those and the other side that were dated 98. I only briefly inspecting the 98s. They sit on the bench in their grease tomb. [My worst case scenario thought was that if those 98s were put on new, there were several years of road racing before the car came to Florida for Solo only duties.]
    Albany, NY
    Liked: 238
    Quote Originally Posted by Jon Jeffords View Post
    Jon, i see no cracks but there are indentations from the balls. Please see photo. Is this a problem?
    Santa Cruz, ca
    Liked: 183
    looking at those races, the ball bearings, and reading the other comments, I would replace them to be on the safe side.
  14. #11
    Memphis, TN, USA
    Liked: 416
    If you want to reuse the current units, magnaflux the cages and the housings and buy new balls. You might consider buying balls that are .0005" smaller which makes for easier movement. Then, when you find cracks in any of of the cages or housings you'll have to . . . . .
    buy the lightened units from Taylor Race (or others). Anything else is really false economy. The price for the magnafluxing makes buying new ones a no-brainer.
    Charlie Warner
    fatto gatto racing
    Liked: 1415
    I think you should replace the joints. The roughness on the contact area of the cages really is a bad sign.
    It is possible to buy undersized balls. I take new CV joints and run undersized balls for the first season and then replace them with the original balls. I run undersized by .001 to .002.
    I do not like how stiff new CV joints can bee and running them in is likely where the pitting starts. If the joint is stiff without a load, you can guess how much stiffer it will be once the power is applied.
    Stiff or bad functioning joints do nothing good for mechanical grip.
  18. #13
    Albany, NY
    Liked: 238
    Going undersize for early use of new CVs sounds like a good thing to do. Where do you source your CV balls from Steve?
  19. #14
    Liked: 1415
    Applied Industrial Technologies, applied.com
  20. #15
    Liked: 1495
    I can't remember where I got the tip, perhaps from one of Carroll Smith's books - but he suggested taking a cartridge roll and smoothing all the edges in the cage.
    I also baked on some dry film lube before re-assembly.
  21. #16
    Liked: 1888
    Jim:
    If you have the usual lightening cuts done on the OD of the body, you will definitely need to go to the undersized balls. once you get your new CVs, let me know what the ball diameter is - i have box of balls of different sizes somewhere upstairs that might work.
    And yes - break all the sharp corners of the cages.
  22. #17
    PLANO
    Liked: 35
    I would replace them Jim , Once they start to pit it is all down hill .
    I have the lightweight Gold GKN on the shelf as well as the standard GKN. I can take them apart a polish ball tracks to free them up .
    Scotty
    Est. 1990
    Taylor Race Engineering
  23. #18
    Contributing Member cgscgs's Avatar
    Indianapolis, IN
    Liked: 39
    Default Emerson Bearing
    I bought a bag of 25 balls, 21/32" (a couple thou undersized) from Emerson Bearing in Boston. 25 cents each (min 25). Also a great source for bearings.
  25. #19
    Vancouver BC
    Liked: 473
    On this topic, I got a smoking good deal on some lightened CVs from a guy who was clearing out his garage prior to a move. I think I paid him $10 a piece for 4 new joints.
    But they seem very tight, so I'm thinking that slightly undersized balls might be a good idea for me, to. If I go that route, is 0.0005" undersized about right (5/10,000), and is there anything else I can usefully do to prep them before assembly.
    What about grease? Is it important to get anything more than a good quality CV joint grease? I've got 4 packets of Moog 3301. Is it suitable?
    On a related note, I've removed and disassemble my existing standard CV joints, and someone suggested to me that because I didn't keep the balls assigned to specific races that they're all junk now. Is that true?
  26. #20
    Liked: 1888
    Half a thou' will usually do it, but not always.
    On the used CV's, as long as the balls show no pitting, it doesn't matter which race they go back in to - it is not a selective fit when they are first made, and the balls will rotate in enough different directions during use that there is no "mateing' of a ball to a particular race, unlike something lik roller bearings.
  28. #21
    Liked: 958
    The Moog grease is the right stuff to use. It has the right additive package for CV joints. It also resists oil and thickener separation from the centrifugal forces. Most general purpose EP greases separate quickly in a CV joint.
  29. #22
    Vancouver BC
    Liked: 473
    Thanks, Richard. Good to know.
    And thanks, Dan.
  30. #23
    Royal Oak, MI
    Liked: 287
    Redline CV grease is also very good, of course, if you're buying, and Valvoline Synthetic is also rated for and good in CV's (unlike Mobil1 synth, which is very much not)...
    Vaughan Scott
    #77 ITB/HP Porsche 924
    #25 Hidari Firefly P2
    http://www.vaughanscott.com
  31. #24
    Liked: 3326
    I've been using the Valvoline synthetic grease for years with no issues.
  32. #25
    Royal Oak, MI
    Liked: 287
    Same here, particularly in our 924's, which have the same CVs of course... I particularly like only mostly needing to stock the one grease, perfect for wheel bearings and CVs alike...
    Vaughan Scott
  33. #26
    Spokane, Washington
    Liked: 17
    I was about to recommend Mobil 1 grease to the original poster. That's all I ever use, and have never had to repack CV joints again. What is your reason for not liking it?
  34. #27
    Liked: 1888
    Note on greases: do not mix CV grease and wheel bearing grease. Many times - but not always - there are components in one grease that are no compatible with components in the other, and the grease will fail - along with your wheel bearing or CV. A mechanic on the TWR GTP team made that mistake many years ago, and the failed CV almost destroyed the car.
  36. #28
    Senior Member xmazdatracy's Avatar
    behind you
    Liked: 130
    I have one lightened CV that is considerably tighter through its plunge than my other three regular lobros. After reading this thread I would like to try some smaller balls. I have .686 balls in all 4 CVs, and would like to ask anyone whom has 6 of the 21/32 size laying around. Or if the grade 25 balls from applied.com are a good purchase?
    Thanks!
  37. #29
    Liked: 931
    Probably should not do this.
    I took an electric die grinder running very slowly. Had about a 600 grit sandpaper roll on it and lightly touched each groove in the outer housing. Repeat a couple of times and it is now nice and loose.
    YMMV
  39. #30
    PLANO
    Liked: 35
    You are correct Steve Demeter.
    I hone and polish dozens of CV joints a year . A 1/2 x 1 1/2 x 1/8 Cartridge roll on an grinder. No need to be changing out balls to different sizes . We charge $25 per joint , And I have to zip tie them when I am done or they fall apart .
    Hone , polish , assemble , and go racing .
    Scotty
    Est. 1990
  41. #31
    Hartford, WI
    Liked: 210
    Default Two processes?
    Quote Originally Posted by SCOTTY81 View Post
    Scotty, do you consider your cartridge rolling to be the honing process or the polishing process? And what then is the other process? Do you do this to both the inner and outer pieces?
  42. #32
    Liked: 3326
    On that note, FYI, only a few 0.0001's (for emphasis, 1/10 of 0.001") needs to be removed to go from way too tight to just right. That's why hand honing is effective. Removing a full 0.001" would likely be overkill.
  43. #33
    PLANO
    Liked: 35
    Jon.
    Sorry for the miss communication. It is more of a hone .
    Yes , I do both the hub as well as the housing .
    As Dave W points out. It does not take much when you are talking 12 surface areas.
    Hone it , clean it and then re-assemble. You will be to feel which track you need to clean up once you assemble the joint and move the hub around
    Scotty
    Est. 1990
  44. #34
    Danbury, CT.
    Liked: 1909
    We like to REM-ISF treat CV'S for the ultimate in low friction. Of course, that's after we Cryo treat them first!
  45. The following 2 users liked this post:
  46. #35
    Buffalo, New York
    Liked: 269
    Quote Originally Posted by cgscgs View Post
    I measured the balls at 0.685
    21/32 is 0.656
    That is more like a couple of hundreths...are there 2 sizes of balls?
  47. #36
    Indianapolis, IN
    Liked: 39
    Mr Bork. The 21/32" balls I referred to are for the CV from an Austin Princess, which is what my Tiga has (outers). YMMV.
    Chuck
  48. #37
    Buffalo, New York
    Liked: 269
    Chuck
    Who knew a princess had balls...thanks for the morning smile!
  49. #38
    Hartford, WI
    Liked: 210
    Default Remind me to tell you the story about......
    You've never been to Thailand, apparently.
  51. #39
    Columbus, OH
    Liked: 482
    I can’t believe it took this long for a balls joke!
  52. #40
    Buffalo, New York
    Liked: 269
    On a more serious note.
    Recently I purchased 4 new lobro CV joints. Two moved perfect right from the package. One was a little stiff but with a touch of polishing it is good. The fourth came so tight I could not move it. Once apart I noticed the balls were not smooth and brightly shined like all of the others. I polished it as is the norm and it still did not move freely. I took balls out of one of the other joints and placed them in the tight joint, problem solved. Has anyone run into this where the ball bearings are a poor grade?
    Robby
