Results 1 to 16 of 16
    Eugene, OR
    Liked: 32
    Default The BANDIT Vintage A Mod Hill Climber
    $6900 or best offer
    Still competitive Vintage A mod built originally by Jerry Kieft.
    Several FTDs and a very fast one minute fifty at Larrison Rock Hill Climb
    Long winning history
    Full history, pictures, SCCA Log Book, testing logs etc
    I'm too old for this thing
    Bridge ported 13B with new seals and rotors 0 hrs (~200 HP at rear wheels on dyno)
    Newly resealed vw tranny with Weddel gears
    New front suspension pushrods with Koni double adjustable shocks and new Eibach springs
    New rear single adjustable shocks
    New Borla SS formula mazda muffler
    New Tilton balance bar
    2 year old Kirkey seat
    Columbus, OH
    Liked: 69
    Really glad this is for sale so far away - it will help prevent a random act of foolishness!!!
    GLWS!
    Craig Butt
    Senior Member Dan Lipperini Jr's Avatar
    Dallas, PA
    Liked: 64
    Thank Goodness that it's so far away, that I have 5 projects right now and we just bought a tractor for the house. But, I do remember Jerry driving it back in the day and it was quite impressive!
    Dan Lipperini Jr
    www.RaceLabz.com
    Austin, TX
    Liked: 15
    Any idea as to when this one was built? Back in the fall of 1992, I dated Jerry's daughter Alexis for a little while. I got to drive a Bandit at an OVR-SCCA event at the old west campus location. At the time, it felt like being strapped into a rocket.
    GLWTS
    Du Quoin, Illinois
    That is so freaking rad! GLWS...
  10. #6
    Eugene, OR
    Liked: 32
    Default Price change and more info
    NEW PRICE $7750 (I need the room in my shop)
    Forgot to say it has a new Tilton balance bar in it as well
    It was built by Jerry Keift in thew '70s.
    For those of you happy it's on the left coast I'll pay half the shipping.
  11. #7
    ASHLAND OHIO
    Default Mazda Bandit AR1 - still alive
    Apparently Tony has done many updates on the car. It was fast years ago, should be faster now. We did have a PP engine in it before but the bridgeport should be very close and may have some other advantages. Car sounds like it is race trim and ready to go with fresh motor. Anyone who wants to get in to autocross or Hill Climbs ..... this is a bargain. Have your doctor check you out before buying. I can guaranty you will need to learn to drive the car and it will be a handful for a while. Just an FYI from Jerry. I even thought of buying it back, but I have a car here which needs finished.
  12. #8
    Member pahillclimber's Avatar
    Quakertown ,PA
    Liked: 14
    Jerry, still working on Floyd's old Reynard?
  13. #9
    ASHLAND OHIO
    Default Floyd's old car
    Sort of visit it every couple days. Was digging into it until I laid the 13 x 15 wide rims on it and found an issue. Entire rear suspension needs redesigned. When younger I was hungrier. Now I just look at it like one more obstacle to surmount. Have engine parts ... 6 lb lighter rotating mass, all balanced. Car would be 12" shorter with similar wings. Do not like some components which could fail under higher down force loads. More obstacles. Transaxle is also something which needs changed. Mark 9s do not like higher stresses.
    I do golf, play pool and fish. Some days that is enough, but I do miss the acceleration factor. Thanks, Jerry
    Quakertown ,PA
    Liked: 14
    Sorry to hijack the thread, I think Floyd would buy it back, as per his buddy, Cosner. As far as MK9, you need to swap in mk5 internals. Moreck had a few failures with his car.
    Senior Member jaweakley's Avatar
    Bloomington, IN
    Liked: 44
    Default Good Luck Tony
    Just wanted to say good luck to your sale.
    Northern NY
    What is the empty weight,overall width and wheelbase? Thank you.
  17. #13
    Eugene, OR
    Liked: 32
    Default Considering all offers - need garage space
    Dimensions
    1134 lbs
    83.5 inch wheelbase
    66 inch rear track
    64 inch front track
    uses FA tires
    measurements are approximate
  19. #14
    w-b twp. pa.
    Default Still available
    Quote Originally Posted by tonychilton View Post
    Dimensions
    1134 lbs
    83.5 inch wheelbase
    66 inch rear track
    64 inch front track
    uses FA tires
    Is is this still available?? I've known this car for years
  20. #15
    w-b twp. pa.
    Default Call
    Quote Originally Posted by fc99 View Post
    Can you give me a call if it's still available 570-760-1396
  21. #16
    Eugene, OR
    Liked: 32
    Default Car is Sold
    Car is Sold
