Hello
My name is pierre, I am french.
In France formula vee has not had a great success, popular sport formula is " formule Renault " with national manufacturer Renault engine
I have a chassis called "formule libre" which look like formula vee
In order to modify this chassis built with vw swing axle gearbox , I seek informations for suspension tie assembly at rear of frame in the continuation of the gearbox
Having no interlocutor to question in France so I solicit you for some technical info
I understand that tie rod point of articulation is in the longitudinal alignment with side gear diff
please can you confirm it
On the other hand, I can not tell whether the point of articulation must be at the same height as the wheel shaft
i suppose that at same height there is only a variation of camber If joint is higher or lower there is slight toe variation
No toe in for rear axle but isnt it interesting to correct tranverse axis variation of the car at acceleration or braking with modification for suspension arm ball joint position
which values are correct ,
thank you very much for your informations
greeting from France
pierre
