Results 1 to 17 of 17
    Buffalo, New York
    Liked: 269
    Default Fuel cell rotary molded vs bladder
    I have been looking at new fuel cells and the one which will fit my car the best is a rotary molded (hard rubber) fuel safe. All the other wedge shaped cells are a softer bladder material. Both are rated the same. Is the hard rubber less safe in an incident?
    Robby
    Zink Z10
    texas
    Default fuel cell bladder vs rotomold
    Robby
    Zink Z10
    For what it is worth: CVAR down here in Texas specifies bladder type fuel cells. I am currently going through
    A Lola equipped with a rotomold tank and intend to take it to the next race to get a specific yes or no from the tech inspectors. I will post the result.
    Nick L.
    Liked: 956
    Robby
    Zink Z10
    Robby,
    Have you tried having your existing cell repaired and recertified? I have a cad drawing if you need dimensions for a new cell.
    Dan
    texas
    Default CVAR approves RotoMold tanks...
    Quote Originally Posted by nickal View Post
    Nick L.
    Well, the CVAR tech guys said the rotomold tank was just fine. Make sure foasm is fresh. and enclose the tank in an aluminium container.
    NL
    Liked: 1493
    The problem with that solution is that you won't be able to race it anywhere else....
    Buffalo, New York
    Liked: 269
    Fuel Safe recertified the cell, building new container.
    I have a brand new Fuel safe cell that does not fit.
    Rob
    Not sure I agree with you Rick. The GCR states: . "All safetyfuel bladders shall be constructed and certified in accordance with the FIAFT-3 or higher (FT-3.5, FT-5, etc.) or SFI 28.3 specifications" <snip> "All safety fuel cells shall consist of a foam-filledfuel bladder enclosed in a metal container at minimum."
    Then from ATL's own site the FIA FT-3 Sports Cell properties specifically refer to the "bladder" as a "Hard rubber all fuel bladder".
    Buffalo, New York
    Liked: 269
    It says FIA/SCCA approved on the cell. Can't imagine it a problem as the car I am putting it in previous owner had a only a bladder with no metal container and it passed tech....
    Liked: 1493
    when you said roto-molded I was thinking of those heavy plastic cells. didn't realize there was a roto-molded cell that passed the FIA spec.
    You are on the right path....almost like the JAZ type cheap-o cells or catch cans...just with foam inside and placed in a metal enclosure. They aren't as flexible as your what we think of when we think "fuel cell bladder", but not so rigid that you envision it shattering/cracking if hit with a hammer. ATL calls it "semi-rigid" in their marketing literature.
    Personally, I wouldn't use one, but that's likely due to my ignorance about them and the FT3 spec. I would prefer to stick with something that deforms to a large degree with the enclosure.
    Liked: 1493
    JAZ was specifically what I was thinking about....
    Buffalo, New York
    Liked: 269
    Appears to be able to deform closely to the "other" bladders but at that point you should really be worrying about how much YOU can deform. i have seen all types of fuel cells ripped from PRod cars, both types hold up and both types rip open. Maybe if we didn't use the minimum allowed metal thickness for the containers they would be safer as well.
    Buffalo, New York
    Liked: 269
    Oddly both types of bladders have the same FIA specs. So either the roto-molded bladder is better than suspected or the flexible bladder isn't as good as originally thought.
    Or both...
    Buffalo, New York
    Liked: 269
    Or both...
    If it was SCCA alone I would worry more...
    Member Drake's Avatar
    nj
    Liked: 17
    Any word as to which lasts longer or there ability to handle ethanol?
    Buffalo, New York
    Liked: 269
    Quote Originally Posted by Drake View Post
    All cells with FT3 rating are good for 5 years and can be recertified for 2 more. Not sure if the are ethanol compatable but ATL says they are high impact and heat resistant, and balistically self healing. Also they are not plastic as the Jaz cells, but a molded hard rubber, just like that one in your wallet from jr high school!
