PLEASE SCROLL DOWN TO BOTTOM OF POST FOR THE CURRENT CAR, DROPBOX LINK, AND LIST / PICS OF EVERYTHING. CAR, TRAILER, SPARES, PIT EQUIPMENT, CHASSIS SET UP EQUIPMENT. Thanks
We are selling one of the 2 F1000 race cars we currently run. In the pics from the Drop Box link you will see 2 race cars, both are Orange bodywork, both cars are identically prepared (save front lower A Arms) and all improvements inclusive of Chassis Strengthening have been done to each car. The car for sale is #42, white front and rear end plates, black A arms.
You can see in the pics (welding shots) where and how we bolstered the chassis (GUSSETS, more tubes), we re-clocked the front Dampers as well for easier access and changed the wheel motion ratio to 1:1. now both ends of the car are 1:1. In addition the cheesy internal floor plate that bolted in was replaced with a steel plate that is now welded into frame rails. Pedal box brake assembly mounting plate with tons of front rear adjustment and NO FLEX when you push the pedal like it should be, NONE. We did most everything on these cars in the rebuild. The rebuilds were done in 2014 / 15. The car for sale was rented to Lappers this past year, no accidents, no crashes and not driven even close to the limit of the car.
starting at the front of the car moving to the rear:
- strengthened chassis
- new bolt in / bolstered pedal box brake assembly mounting plate / 2 pedal foot box
- clutch moved to steering wheel
- new chassis powder coat
- new brakes, 4 piston Wilwoods (front and rear)
- new rotors
- new pads
- re-clocked front dampers (180 degrees)
- front wheel motion ratio of 1:1 with new BRD Bell Cranks
- new shifter Push Pull cable
- new Rod Ends Aurora Golds
- new brake lines and fittings with quick disconnect rear lines
- BRD Dry Sump System
- new BRD front wing profile (2015 BRD Profile)
- new wing flaps (BRD 2015)
- new Aim Data System (no damper sensors) All engine vitals, brake pressure front and rear, f1 style Aim Formula Wheel, GPS Track Mapping
- new Aluminum front underside floor plate
- new Tea Tray
- new full width floor (BRD) A real flat bottom car inclusive of getting rid of the rear bulkhead bottom frame rail step
- BRD Gen ii bodywork (Low Drag)
- new BRD 2015 Rear Diffuser)
- new BRD rear Aero End Plates Gen ii
- Ohlins / rebuilt dampers by The Shock Shop Chris Bellings (just prior to his retirement)
- new radiator
- new oil cooler / radiator
- new hoses
- new floor
- new AN hardware throughout
- new paint
- carbon fiber wrapped front wing, rear wing beam, rear wing upper, front flaps
- 3M leading edge protection
- new chain
- new gears front and rear
- added NACA DUCT side cooling vents to side panels
- new Air Intake box
- new fuel pump
- new starter
- new axles
- new CV joints (Volkswagon and BMW)
- new SPARCO belts good to 2020
- new drive gear cluster
- new battery
- new ignition power cutoff switch
- new wheels (Youngbloeds) 7" / 9" Also have a spare set
- new shark fin radio antenna
- wired PTT switch on wheel
- No lift shift up / Auto Blip down shift system (Flat Shift Pro)
we replaced 98% of the bits on the cars, Its probably easier to tell you what we didnt replace on the cars.
Maintenance History
We started July 2015 with A fresh GDRE GSXR 1000, fresh oil and oil filter, every 2 hours the oil is changed, every 4 hours the oil and filter are changed. Diff is inspected and serviced after every 120 minutes of on track duty, Chain replaced in August 2016. Nut bolt check after very session, chain waxed after every time the car comes off the track and tightened if needed. Once track days are done its back to the shop where we remove bodywork, remove pod floors, remove diffuser and inspect car from front to back, top to bottom. Blow the car out, vacuum the car, clean, if it needs something it gets replaced with new bits. We are fussy! Car has performed near perfect.
New / Used Parts in the Parts Bin (our used parts are all fully functional, NO junk)
- new fuel pump in the box
- new starter in the box
- new chain in the box
- new front and rear gears, (some used some not, NO JUNK) providing full range of ratios that work with an f1000
- new and some used Suspension springs, full compliment of weights, fact is we rarely changed the spring rates as our driver never really pushed the car to where she would notice a spring change
- new Drive Flange kit complete
- used, fully functional water radiator
- vast used selection of AN brake lines with fittings
- spare set of Youngbloed 7" / 9" wheels
- trailering wheels
- BBS 3 piece wheels on the shelf (these came with the car when I bought it, I have never used them, I think there is enough for 2 sets of wheels but like I said, we have never used them. whatever is there goes with the car
So you will see 2 cars in the link, some shots of the Grey chassis (the one for sale) and shots of the Orange Chassis, both are identical under the skin. #42 uses STOHR GEN 1 lower front A arms, that is the only difference.
September 2016 was the last time the car was run, here is the compression test numbers just after it came off the track but was allowed to cool down enough to touch. Starting at driver left moving to the right across the cylinders:
cyl #1 190, cyl #2 187, cyl #3 194, cyl#4 190. Compression test was done with a relatively new MAC Tools Compression tester.
If you require additional pics or have more questions feel free to ask.
I have well over 75K USD into this car. Price as listed for sale $39900.00 USD
