Results 1 to 6 of 6
    Senior Member rohartman's Avatar
    Galena, Ohio
    Liked: 18
    For Sale Elite prepared 2L Flywheel with 5.5 Tilton clutch***SOLD***
    ***SOLD***
    This flywheel is on a fresh rebuilt Elite S2 engine. 110 tooth ring gear in excellent shape, new 5 1/2" Tilton clutch disc with 1' x 23" spline pattern. A Tilton OT-III single disc clutch, gray springs with new fork fingers pressure plate, the clutch cover is used but EC. SOLD
    or will trade for Tilton OT-2 clutch, 7.25" orange spring with S2 flywheel and 1" x 23" disc.
    Liked: 3787
    Folks that want to build a pinto to compete with a zetec... this is an important piece to reach that goal.
    OBTW, Randy is as straight up as they come. If he says it is top shelf, it is.
    Ca
    How much does the entire setup weigh?
    Envoyé de mon iPad en utilisant Tapatalk
    Senior Member xmazdatracy's Avatar
    behind you
    Liked: 130
    How can you tell its a orange spring? I have might have one that needs work...
    Galena, Ohio
    Liked: 18
    Quote Originally Posted by TE37 View Post
    The flywheel with ring gear weighs 14.4 lbs most that weigh is inboard. The pressure plate and clutch disc is 4.0 lbs, so total weigh is 18.4 lbs
    It should have a orange dot on the pressure plate if not does it have a part# on the front?
    Galena, Ohio
    Liked: 18
    Thank you for the kind words.
