Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 122
  1. #41
    Elizabeth, CO
    Liked: 74
    Quote Originally Posted by TedV View Post
    Make it 26 in CM. I fit and my Panasport rims fit. Attempted to modify my entry online and it does not seem to be cooperating. Guess I will get it changed at registration check in, out in the land of planes and corn.
    Nice!! I think you can email Brian Harmer and he'll update your registration. He fixed mine...
  3. #42
    Midland, MI
    Default Brian's Contact Info...
    Quote Originally Posted by Barry Ott View Post
    Brian Harmer
    Rally/Solo Program Manager
    1-800-770-2055
    bharmer@scca.com
    Chris Pruett
    Swift DB1
  4. #43
    San Jose Ca
    Liked: 80
    Is this the largest CM class ever, or is there another hay day of the CM class?
    It doesn't sound like it or someone would have said something already.
    Ben
  5. #44
    Midland, MI
    Default Forbes...
    Quote Originally Posted by CM/FFdriver View Post
    Ben
    At 26, it is largest CM field at Lincoln. Previous high for Lincoln was 21 (2009 and 2012).
    As for absolute largest entry, that's a good question. Both times I ran CM at Forbes it was larger; 36 in 1997 and 30 in 2002. Perhaps Peter Calhoun or Jim Garry can chime in as were part of the class during that period.
    Chris Pruett
    Swift DB1
  6. #45
    Contributing Member TeamFRD's Avatar
    FL, USA
    Liked: 15
    Default Paddock check in
    No instructions. No links. Confused.
    TeamFRD-1988 Van Diemen RF88-1267 FF1600 Solo:CM#99/199 http://yspect8.weebly.com
  7. #46
    Midland, MI
    Default Paddock...
    Quote Originally Posted by TeamFRD View Post
    Yea, it's messed up this year due to record entry. From what I have read, it will be another 24 hrs until the Paddock systems opens...
    Chris Pruett
    Swift DB1
  8. #47
    Albany, NY
    Liked: 238
    Quote Originally Posted by -pru- View Post
    Oh man, taxing my memory for sure. I will climb into the very hot attic later this week to check my records. But I remember in the early days of the "new" CMod when F440 and FF were combined the entry was pretty high. It may have hit 40 between it's first year (1990) and the next few.
  9. #48
    Midland, MI
    Thanks Jim! Via the web, I found results for 1995 onward so any insight on pre-95 would be appreciated.
    Oh, I'm up to 1999 which is now new CM entry high with 38! Wow...
    Chris Pruett
    Swift DB1
  10. #49
    Midland, MI
    Default Past Solo Nationals Results
    FYI: Here are the two sources of past Solo Nationals results that I have found:
    ~ Milwaukee SCCA : Past Solo Results - Archives
    ~ SCCA Solo : Solo Archives
    Chris Pruett
    Swift DB1
  11. #50
    Pittsford, New York
    Default Good Times
    I just dusted off a couple of my old results booklets.
    In 1990 Stuart Lumpkin won and I think the car count was around 32 (I didn’t run that year.)
    In ‘91, there were 36 entries and 34 starts. Jeff Watson won.
    In ‘92, there were 41 entries and 40 starts. Peter Raymond won in a Citation that is still being autocrossed (many owners.)
    I think it was ’92 when I worked HS and got to watch Pru slide a Cossworth Vega around? I allways liked that version of the car for some reason.
    Craig
    Last edited by Craig Henry; 08.15.16 at 11:22 PM. Reason: Incorrect F440 comment removed
  13. #51
    Albany, NY
    Liked: 238
    F440s were in CMod from the beginning. I was on the SEB when CMod was revamped and we placed the 440 into the class along with the vees and S2000s.
  14. #52
    Pittsford, New York
    Default My bad.
    Jim, Oops.
    To be honest, I did scan the results and no 440’s stood out. I just rechecked and now I see several. How could I forget Jim Murphy and all the others? Getting old(er) and blind.
    Craig
  15. #53
    Albany, NY
    Liked: 238
    We're all there brother
  16. #54
    Elizabeth, CO
    Liked: 74
    Like Pru said, it's a mess, but I'm sure they'll get it straightened out!
    Here's a little info, based on the last couple years:
    - There will be a link on the right side of the Nationals page, where the run/work order, etc is.
    - The link will take you to an interactive map of the Lincoln site. It will have locations for tech, registration, courses, TnT course, PADDOCK, etc.
    - In the Paddock area, each parking spot will be color coded to designate if it's available or reserved.
    - To reserve a spot, you select one of the available spots, enter you information (scca number, name, or something like that???) and submit your request. The spot will change color to designate that it's reserved.
    - If you hover over a reserved spots (or maybe click them), the application will tell you who is in that spot. Use this to confirm your reservation from the last step
    - There's a search function to help you find other people.
    I thought it was a little clunky but overall, it worked pretty well.
    As you can imagine, adding more rows means updating the application, which takes time...
    good luck! Oh, and don't hold me to this stuff, it's based on my foggy memory and things will probably change a little.
    Barry
  17. #55
    Austin TX
    Hello all!
    I'm looking to get into a CM car in the coming year (maybe 2 years). I am currently running in a DP Miata. I am wondering if I could test fit in a few chassis at nationals. I am 6' ~220 lbs and have a largish shoe size (13). From my research, the Van Diemen chassis looks like the best option for me but I would like to check. If any of you would be agreeable to a test fit one evening at nationals let me know. Good luck to everyone, see ya in Lincoln
  18. #56
    Silverton, OR
    You are welcome to test fit my Reynard. I bet you'll find my car is the roomiest of anything in grid.
    Andy
  19. #57
    Austin TX
    Thanks Andy! I'll stop by your grid and figure out where you ended up in paddock. Good luck!
  20. #58
    SoCal
    Your welcome to try on my Van Diemen. Bring skinny shoes, pedal box is <10" wide. Size 13 may have your toes in conflict with the sway bar end links.
  21. #59
    Silverton, OR
    Ditto on the skinny shoes. My car is wide enough it has a dead pedal. My size 11 feet can operate the pedals, but not when I'm wearing running shoes. A little work could be done to reconfigure the footbox in my car.
    I am doing a Tuesday / Wednesday work assignment, so after we leave impound I can give the grand tour of the car - no rush to stow everything.
    Andy
  22. #60
    Elizabeth, CO
    Liked: 74
    Your welcome to try mine too, it's essentially the same as Eric's (ewcmr2). I suspect that David's shoes are about as big as can work, so you can try those shoes too.
    I had an '88 Reynard that was pretty spacious too, so that's a good option if you can find one. In fact, my car was sold to a Dude in Fort Worth and then it mostly disappeared, maybe you could find that one??? I wish I could remember his name....
  23. #61
    Midland, MI
    Thad Bolline?
    Chris Pruett
    Swift DB1
  24. #62
    Elizabeth, CO
    Liked: 74
    Thad Bolline?
    Yes, Yes, Yes!!
    Thank you!!!!
  25. #63
    Austin TX
    Thanks, I'll bring my skinny shoes and try as many as I can. Sounds like my feet are the main problem. I'm flying in Wednesday but will have a pretty full schedule. Thursday or Friday would be ideal. I work 3 and run 5. Looks like y'all run 2 work 5 so if the morning is easier/preferred I'm flexible.
  26. #64
    Austin TX
    I'm co-driving Steve Hudsons DP car #182. I'll try not to hit any cones for those of you working course
  27. #65
    San Jose Ca
    Liked: 80
    Don't worry about the cones you may hit, worry about the cones that will be down accidentally when you pass by, if you don't pay me now HEHE!
    Ben
  28. #66
    Senior Member Dave SanF 50's Avatar
    Alameda in SF Bay area (CA)
    Liked: 34
    Default shoe size
    A few of the CM/FF racers I know will buy a couple of sizes smaller racing shoe to fit into the foot box better. Running shoes are a no no in a formula car. They are too wide. Even with my small size 8 feet, I can not wear running shoes. When I autoX my FF, I bring my race driving shoes and will change into them for the runs and then change back to other shoes for working on course and walking around.
    A racing shoe a couple sizes smaller is OK for a 30 minute race or a 45 sec solo run-you are not planning on running a marathon in them.
  29. #67
    Liked: 3787
    My racing shoes are so small my second toe is actually resting on top of my big toe when in the shoe. I wish my parents had taped my feet when i was young.
  30. #68
    Saint Louis, MO
    Liked: 310
    There has been a change in run/work order. Heat 6 has been consolidated into earlier heats. CM will work Heat 5.
  31. #69
    Sunnyvale, CA
    Default C-Mod class
    I will be driving too! See also my related post http://www.apexspeed.com/forums/showthread.php?t=74968
    25 drivers! woo hoo
    Chris More
    Palo Alto, CA
    http://www.chrismore.com/
  32. #70
    Midland, MI
    Default 2016 CM Solo National Entry : 8/22
    Confirmed 2016 CM Solo Nationals entry now 26:
    4 Vernon Maxey 2004 Solo Vee LynxB
    5 Phillip Leavens 1998 Van Diemen RF-98
    19 David Fauth 1995 Van Diemen RF-95
    21 Ted Visscher 1988 Van Diemen RF-88
    31 Brent Cary 1988 Reynard FF1600
    46 Joshua Parker 1985 Reynard 85F
    50 John Engstrom 1985 Swift DB1
    60 Ben Martinez 1984 Van Diemen RF-84
    70 Jon Krolewicz 1982 Reynard FF1600
    77 John Whitling 1989 Caracal Solovee
    83 Ray Thomas 1983 Reynard FF1600
    84 Robert Qualkinbu 1990 Adams Aero Solo
    87 Krystal Lavender 1985 Van Diemen RF85
    91 Bruce Faucett 1984 Van Diemen RF-84
    94 Eric Clements 1994 Van Diemen RF-94
    105 Joe Goeke 1998 Van Diemen RF-98
    119 Barry Ott 1995 Van Diemen RF-95
    121 David Flesher 1988 Van Diemen RF-88
    146 Heyward Wagner 1985 Reynard 85F
    150 Chris Pruett 1985 Swift DB1
    160 Christopher J More 1984 Van Diemen RF-84
    170 Andrew Howe 1982 Reynard FF1600
    177 Johnny Billingsley 1989 Caracal Solovee
    187 Brandon Lavender 1985 Van Diemen RF85
    191 Colin Faucett 1984 Van Diemen RF-84
    194 Jonathan Clements 1994 Van Diemen RF-94
    CM is now the largest Mod class!
    Chris Pruett
    Swift DB1
  34. #71
    Santa Cruz, ca
    Liked: 183
    man... I wish I was going...
  35. #72
    Elizabeth, CO
    Liked: 74
    Quote Originally Posted by chrisw52 View Post
    Next year!!!
    Mervich, you too!
    Barry
  37. #73
    SoCal
    And Schilling! (Maybe he'll be done with titanium body mods next year)
  38. #74
    FL, USA
    Liked: 15
    Default Carb Jetting
    My Dad asked about how the elevation change will affect the car. He expects it will run rich since I'm going from 14 ft to 1100 ft.
    Please share your experience changing jets for Lincoln?
  39. #75
    Midland, MI
    Default Lincoln Jetting...
    David,
    Since we started running in Lincoln, I've never changed jets, and I have not noticed a major drop in engine performance. Then again, the sites I normally run are in the ~600' (Oscoda, Toledo, Peru) to 1000' (Wilmington) range. Perhaps someone with a similar elevation change to yours can provide some feedback.
    Chris Pruett
    Swift DB1
  40. #76
    Elizabeth, CO
    Liked: 74
    Back in the day.... I bought my Reynard from a guy in Upstate NY, it was jetted by Quicksilver for, I assume, that elevation (a few hundred feet or so) I live in Colorado so our sites are generally > 5200' elevation. I struggled for a little while when restarting a warm engine. Ultimately, I leaned out the jet involved with the idle circuit (It's been way too long for me to remember the specifics) and then it started fine. Note that it always started, it would just take some futzing and some cranking. I suppose it would have run a little better and made a little more power if I had tweaked the jetting, but it ran fine, it never did anything bad. That experience suggest to me that going up 1000 feet won't be a problem. Maybe not absolutely optimum power, but I wouldn't expect any problems.
    Barry
  41. #77
    Fallbrook, N. San Diego Co.
    Next year!!!
    Mervich, you too!
    Barry
    Maybe, if I run out of things to do being retired and need some excitement.
    Mark
  42. #78
    I have already given it more thought. If I could find a co driver from this area, I could make it work. Lots of time to set that up. I am getting too old for the 28 hr straight through drive alone.
    Mark
  43. #79
    San Jose Ca
    Liked: 80
    I asked the guy at Pierce Manifold here in Calif. and he didn't think it would something I should mess with, it's only 1176 feet at Lincoln so...? he thought that 2200 feet could see a change like 155 main to a 150 main, I asked if they made a 152 or 153 main and he said no but you could drill out a 150 to a 152.5, I "LOL" He thought that maybe with a really good engine making 115 hps you could see 1 to 2 hps, not a gain in Hps just regain the lost Hps but you have to know if it working for you and if you get it wrong you lose more Hps then you gain.
    Ben
  44. #80
    Knoxville,Tn
    Liked: 65
    Have you called Roland to see what he jetted the carb for? When I asked Sam Nelson about about the motor he did in the car I bought, he said unless you are going to run in Colorado, don't worry about it.
    I haven't ran anything in Lincoln tho.
