Results 1 to 13 of 13
    Senior Member jaltaman's Avatar
    Salt Lake City
    Liked: 66
    Default 2013 Phoenix F1K12 not for sale
    2013 Phoenix F1K12
    TURN-KEY F1000 (FB) PACKAGE
    NOT FOR SALE
    This car won the 2015 SCCA F1000 Western Championship and had one of the highest trap speeds at the 2015 SCCA Runoffs. It has been constantly developed and contains all of the factory updates to date.
    THIS F1000 PACKAGE INCLUDES:
    · Ready-to-race Phoenix F1K12 Chassis S/N #003
    · THREE Spare Suzuki GSX-R1000 ’07-’08 engines (4 total)
    · TWO extra sets of wheels (3 sets total)
    · MK Technologies MK2000 Setup Tables & Scales
    · Custom Front & Rear Quick Lifts
    · Transport Wheels (adds clearance for loading/unloading the trailer)
    · Assorted Custom Tools
    · Exhaustive Spares Package (see below)
    · All setup, maintenance and service info
    For more detail, please read on. I can help arrange for delivery and would entertain delivering it myself if it makes sense. Contact me at jwlabrie@comcast.net or 801-671-0498 if you have any questions or would like to see the car. I have lots of pictures and video that I can share as well.
    F1K12 Chassis #003 Complete Package - Description
    Original Delivery Date: February 20, 2014
    This is the “sister” car to the Phoenix Factory Car. It has all the factory updates including custom rear wheel flip-ups, updated rear wings, custom inner wheel covers and new half shafts and tripods. This is an extremely quick and reliable chassis and is ready to race now. The bonus: Over $30K in spares & tools come with this car! Read on for details.
    RECENT UPDATES
    • NEW Hyperco Hydraulic Spring Perches – MAR 2016
    • Quantum Black Dampers re-valved, re-built and dynoed – MAR 2016
    • NEW Upgraded Rear Halfshafts, tripods and tulip cups – FEB 2016
    • NEW custom Front & Rear inner wheel covers – FEB 2016
    • NEW Steering Wheel Wiring Harness – JAN 2016
    • NEW Ugli Gripz – OCT 2015
    • NEW Suzuki Wiring Harness – SEP 2015
    • NEW Geartronics Wiring Harness – SEP 2015
    • NEW Geartronics Lightweight Compressor – SEP 2015
    FEATURES
    • ’07 Suzuki GSX-R1000 S/N T715-119629 currently installed
      • 10 hours run-time to date
      • PowerCommander
    • Rilltech custom tuned headers and exhaust
    • Geartronics no-lift paddle shifting system with upgraded lightweight nylon pneumatic lines and push-to-connect fittings
      • All components serviced JAN 2016
      • New wiring harness SEP 2015
    • NEW Upgraded rear half shafts and tripods FEB 2016
    • Quantum Black double adjustable dampers with Hypercoil springs
      • Freshly rebuilt and re-valved by Harrison Auto Dynamics MAR 2016
    • Momo steering wheel with Strange Engineering quick-release
      • NEW steering wheel harness JAN 2016
    • Taylor Racing Differential
    • Edge Engineering F3-Style “T” Steering Rack
    • Adjustable Front & Rear anti-roll bars
    • Wilwood Forged 4-piston Brake calipers w/ 10” rotors
    • Dual Wilwood Master Cylinders w/ cockpit adjustable brake bias
    • Custom Rear Diffuser
    • Adjustable F&R Dual Element Fiberglass Wings
    • Lightweight Ballistic Battery
    • SCCA approved 10.8 gal. Fuel cell w/ submerged fuel pump
    • RaceMirrors elliptical mirrors
    • Adjustable Pedals
    • Custom Aluminum Belly Pan
      • Spare steel belly pan included
    • Phoenix Raceworks Custom Wheels with lightly used Hoosier slicks
      • Included Lightweight Split Rear Sprockets: 45T, 46T, 47T, 48T, 49T, 50T
      • Included Front Sprockets: 14T, 15T, 16T, 17T
      • Included chains: DID 530 ZVMX GOLD X-RING 75 pin and 76 pin lengths
    SAFETY
    • 4130 Chrome-Moly tubular fully triangulated space frame
    • C.A.M.S. Legal roll hoop with full FEA Validation signed off by P.E.
    • FIA Spec Carbon Fiber front crush box with aluminum honeycomb
    • FIA Spec Head surround
    • Custom poured foam seat by Speed Seat
    • SCHROTH FIA Rated 6-pt Harness
    • Safecraft LT5HAA-SFI Fire System with 3 outlet nozzles
    • SCCA approved LED Rain Light
    DATA ACQUISITION
    The AIM MXL PRO Dash with 16MB of non-volatile RAM provides the basis for complete data acquisition. Sensors wired into this chassis include:
    • Oil Temperature
    • Water Temperature
    • Oil Pressure
    • Front Brake Pressure
    • Rear Brake Pressure
    • Steering Wheel
    • Global Positioning System (GPS)
    • Front and Rear Shock Pots
    • Lamda Controller
    • Wheel Speed*
    • Timing Beacon*
      *Not used but included as spares
    AERODYNAMICS
    • Removable custom side pod chimneys
    • Custom rear wheel flip-ups
    • Custom lightweight Front and Rear inner wheel covers
    • Custom integral front splitter/T-Tray
    • Camloc fasteners for body
    • Aero washers on rear wing
    • Countersunk washers and flat head screws on floor
    • Custom Rear Diffuser with strakes
    • Adjustable Front Fiberglass Wing with Adjustable front Wing Flaps
    • TWO Adjustable Dual Element Rear Wings:
      • Low Downforce version (installed)
      • High Downforce version
    • Custom gurney flaps
    CONVENIENCE
    • Staubili Clean-Break Coupler brake line disconnect
    • Front & Rear TRANSPORT WHEELS for easy loading and unloading
    • Steering Wheel wired with Neutral Button and Push To Talk (PTT) via Milspec Coily Cable with Deutsch Connector
    • Edge Engineering Gear Position Sensor Mount for Geartronics
    MISCELLANEOUS
    • SCCA Homolgation Certificate
    • SCCA Logbook
    • All setup data included
    INCLUDED CUSTOM TOOLS
    • Lightweight Aluminum Toe Bars
    • Formula SAE Spec Tow Bar (for towing or hoisting the chassis)
    • Front and Rear Transport Wheels (for loading/unloading the car in the trailer)
    • Front Nose Transport Brackets (saves space in the trailer)
    • Front & Rear Quick Jacks
    • Steel Rear Lift Bar – allows you to safely lift rear of car with common floor jack
    • Vice receiver for Stub Axle removal
    • Custom Socket for Stub Axle removal
    • Taylor Differential Collar Socket
    • Hex key for Phoenix Oil Pan bolts
    • Hex Key for Custom Header bolts
    • Steel Rods for chain tensioning
    SPARES
    • TWO Sets Phoenix Raceworks Wheels with lightly used Hoosier Slicks
    • NEW SafeCraft Fire Bottle
    • NEW Ballistic Battery
    • GEARTRONICS
      • NEW GCU
      • NEW Assorted Push-to-connect fittings
      • NEW 50’ Nylon Tubing
      • NEW Valve box
      • NEW Seals, o-rings, etc.
      • Compressor
    • NEW Upgraded Rear Half shaft
    • NEW Custom Radiator
    • Rear Pushrods (2)
    • NEW Banana clips for chain tensioning
    • NEW Bosch O2 Sensor
    • GSX-R1000 SPARE PARTS
      • Clutch slave cylinders (2)
      • Clutch push pins
      • Starters (4)
      • Thermostats
      • Fuel Injectors
      • Rectifiers (3)
      • Air intake Horns (4)
      • WIX Oil Filters (11)
      • And more
    • BUMP SHIFTER KIT
      • Includes Shift lever and Cable and hardware
    • Rear Upper A-Arm w/spherical installed
    • Front Wing with Whiskers & Endplates
    • Rear Wing Main element
    • Rear Wing Upper Dual Element (Low Downforce)
    • Rear Wing End Plates
    • NEW Rear Attenuator
    • NEW Front & Rear Brake Rotors
    • NEW Front & Rear Brake Pads
    • HYPERCOIL SPRINGS (PAIRS)
      • 400#, 500#, 550#, 600#, 650#, 700#, 750#, 800#
    • Steel belly pan
    • Lugnut Rebuild Kits
    • NEW Engine Heat Shield/Scatter Blanket
    • NEW Suzuki GSX-R1000 Throttle Bodies (2)
    THREE Complete ’07-’08 GSX-R1000 Engines:
    SPARE #1 - S/N T715-136221
    READY TO GO - Phoenix Oil Pan and oil line fittings already installed.
    HOURS OF USE: 4
    Includes ECU and Throttle Bodies
    SPARE #2 - S/N T715-117045
    FRESH REBUILD.
    HOURS OF USE: 0
    Includes CUSTOM ALUMINUM ENGINE STAND
    SPARE #3 - S/N T715-120153
    NEEDS REBUILD. Already packaged on pallet ready for shipping.
    HOURS OF USE: 18
    Includes ECU and Throttle Bodies (already packed with the engine)
    MKT2000 - with 10"x10" Intercomp SW500 E-Z Weigh Kart Scale System
    The MKT2000 scale platform is a compact, lightweight platform system that’s easy to handle and set-up and is perfect for the F1K12. Includes runoff ramps and all hardware and removable feet. The Intercomp SW500 scale system features:
    · 400 lb capacity per pad
    · 1,600 lb system capacity
    · View any combination of scale pad weight & percentage
    · Target tune feature
    · RS232 output
    · Certified to 0.1% accuracy
    · 4-Bolt load cell design
    · Stores 100 chassis setups
    · Baseline setup recall
    · Center of gravity calculation
    · User selectable display modes
    · Giant 0.5" display characters
    · Backlit for night use
    System includes four 10" x 8" x 2" (254 x 203 x 51mm) billet scale pads, cabled indicator with case, standard 9-volt battery.
    Last edited by jaltaman; 08.05.16 at 10:31 AM. Reason: We're not selling, we are racing.
    Perth western Australia
    Default More Information
    Hi J,
    Could you please supply more photos & video. I may have a buyer in my network.Would be great to have another Phoenix here in Australia.
    Cheers,
    Derek
    Salt Lake City
    Liked: 66
    Hello Derek.
    I just sent you a PM. Please give me a shout if you have any more questions.
    Cheers,
    John
    Senior Member drdestructo's Avatar
    White Salmon, WA
    Liked: 30
    John
    You never even offered me a few laps in this beast . I'm heartbroken.
    Salt Lake City
    Liked: 66
    Hi Russ!
    Heck, I only saw you that one time in Portland since I've had the car, right? Besides, you should thank me - if you had driven it you would have bought it!
  9. #6
    Australia
    Quote Originally Posted by bmsrac View Post
    Hi J,
    Cheers,
    Derek
    A lot of spares!! sounds like a great package hopefully it makes it here to WA
    Salt Lake City
    Liked: 66
    Default Pictures are here
    Okay, here's a link to a bunch of photos, some of which were taken in the last few days (specifically the ones showing the car sitting on stands with the nose mounted backwards on the nose transport brackets).
    https://drive.bitcasa.com/send/4Dya3...0dl0_sXZ-BcFRU
    And too funny - I thought WA was short for Washington - I just realized it means Western Australia!
    Cheers!
    John
  12. #8
    Salt Lake City
    Liked: 66
    I apologize - apparently Bitcasa is closing their personal drive offering so I had to remove the pictures. I will find a new locale and get them posted. Sorry for the SNAFU.
    Note: Price reduced!
  13. #9
    Salt Lake City
    Liked: 66
    Default Pics at last
    Here's a bunch of photos. Contact me if you want more.
    Salt Lake City
    Liked: 66
    Default No longer for sale
    We're going racing instead.
    Green light for the 2017 season as well!
    See you at the Runoffs!
  15. The following 5 users liked this post:
  16. #11
    Alpine California
    Liked: 273
    I've known a lot of racers over my last 4 decades of SCCA racing and I can tell you without a doubt that John Labrie is one of the most hard core, wanna win, stick with it drivers I've ever known.
    I've seen John come in 45 minutes before pre grid with all sorts of stuff going wrong and he makes the show.
    Labrie hands down has more seat time in an FB than anyone, even Coop.
    Onward to Mid Ohio and Indy....oh and maybe a Majors at COTA next year.
    Gary Hickman
    Edge Engineering Inc
    FB #76
  18. #12
    Palo Alto
    Default Best News
    John,
    Your return is the best racing news I heard in months! Can't wait to be on track with you.
    Randy
  19. #13
    Salt Lake City
    Liked: 66
    Thanks Gary - if at first you don't succeed...
    And thanks Randy - I'm looking forward to seeing you on track as well!
