This rare aluminum Elva MK IIB is one of four MKIIB’s built by the Elva Engineering Company at the London Road, Bexhill, workshops during 1957. The car has spent most of its recent years in private collections having seen little track use which has protected the many original features. It was raced by UK guest driver Allan Miles at a Mid Ohio event in the mid 1980’s, and later appeared at the 35th ELVA anniversary meeting at Road Atlanta in 1990. Since 1990 in storage,
The motor most likely is fresh, compression even at 175. Starts up immediately and runs smooth without typical climax, chain and gear noise. No sign of leaks. The doors operate perfectly and have the original latches.
Sometime during its early racing career , car had a narrow roll hoop, full width windscreen, tonneau cover with Dzus fasteners
Chassis number 100/34
Original chassis ID plate (verified by Elva )
Original frame is in excellent condition
Original brass radiator
Proper MGA gearbox
Koni shock absorbers
Coventry Climax FWA motor
Original hand brake and cable
FIA spec spare tire holder
Original finned aluminum drum brakes (excellent inside and out)
Original 48-spoke 15? wire wheels ( spare included)
Bolt in roll-bar, full width roll bar included ,
Legs for original small roll-bar are present, easy to install a narrow drivers side roll bar
Original head lamps (including original Lucas glass and housing)
All aluminum alloy body panels appear to be original except center of rear clam shell
Original parking brake handle and cable
Original seats
Original steering wheel
Full original type Lucas generator and regulator
All suspension arms appear to be original and excellent
Items replaced sometime during storage :
New Tilton brake bias assembly
Two Girling brake master cylinders
New brake shoes (all four corners)
New wheel cylinders (front wheels)
New Koni shocks (dampers), all four
Dunlop L series tires, look very good, full tread , not driven
Items Replaced 2016
Fuel cell bladder, foam and pick up tube
Fuel flush (three new lines)
Battery
Improved ground cables
Oil filter, ( old filter cut and inspected , very clean, no debris found)
Generator belt
Extras
Original metal fuel tank
Price:
Asking $85,000, will accept trades.
Contact:
Kim Baker
413 329 0214
baker@vintageracecarsales.com
More photos on our website!
