does anybody have a picture or diagram how to strap / use OMP arm restraints? they came with the loop strap already through the d-rings on one end of the arm pad and the other end of the arm pad has d-rings and just a flat strap. I assume the loop strap will go down to the cam lock and put the shoulder buckle end through it. But I can't figure out how to get the flat strap to hold the pad around my arm with the loop strap already using the d-rings on the other end.
I think they're the same style as Sparco if that helps anyone answer my question.
thanks,
mike
