Results 1 to 16 of 16
    Member Wally O's Avatar
    Seminole FL
    Default FE FSCCA #56 - Sold
    FE 14 for Sale
    Chassis #56: I bought it as a kit and assembled myself in late 2003. I do all my own maintenance and setup. The car has been meticulously prepared thru out the years which my fellow racers throughout the country
    will attest to. I have won multiple Regional championships, SAARC and with Grandson driving multiple Nationals and Majors and a Runoffs podium.
    2 sets of slicks with 2 sessions from Daytona runoffs, 1 set with sticker rains from runoffs. Fresh motor up to specs which will be returning from Enterprise after Daytona runoffs inspection.
    Newest updated Comprent transmission bought at Runoffs. CDS with GPS with added oil temp, Lambda, steering and brake bias. New radiators, New wood bottom.
    New starter. New stator. New front brake calipers. Rebuilt steering rack. New splitter. New oil and coolant lines. Custom Speed Seat and insert. Droped floor for big feet. Car was setup for 6' and 5' 6"
    drivers. Custom changeable pedals and drop floor insert. Allows 10 minute driver change including adding weight. New Comprent head surround and padded kevlar side panels. Schroff pull-up belts so I can buckle
    myself in. Custom upper bar for proper Hans belt location. Complete spare nose assembly with matching graphics. Complete spare rear wing assembly. Fuel cell 2 years old. Small clutch master cylinder (easier).
    Car is vinyl wrapped. I'm 200 lbs and can make minimum weight. You won't find a better prepared car with large spares package that will keep you running at all events.
    Car with pit equipment and all spares $45,000.00. Will consider parting out.
    UPDATES INCLUDE:
    Penske shocks
    Steering shaft (apex joints)
    Floating Rotors
    Tow Hooks Front and Rear
    Throttle Cam
    Cam Lock Body Fasteners
    New Muffler
    Oil cooler
    Cockpit adjustable front sway bar
    Honeycomb crush box
    Updated fuel filter
    Thermostat kit
    Both rear wings setup for both actuators
    MC Technology Pit Equipment:
    Front and rear jacks
    Toe bars
    Toe board for measuring, includes camber gauge
    Low jack stands
    Stand for storing body panels in shop
    Spares and stuff:
    Custom car cover
    Motor
    Transmission fresh from Comprent with large actuator
    Transmission gears
    Comprent large actuator
    Actuator springs
    Slave cylinder rebuild kit
    Throwout bearing
    Transmission tools
    Alternator
    Starter
    Comprent A-frame setup jig
    A-frames
    Front calipers
    New brake pads
    Front and rear uprights complete
    Honeycomb radiator screens
    New spare wiring harness
    Muffler kit
    Heims
    To many small spare items to list
    Contact: Wally c:727-460-2154 or Osingaco@aol.com
  2. The following 8 users liked this post:
    Contributing Member Chet Zerlin's Avatar
    Naples, Florida
    I've raced against Wally for a number of years and I can attest that Wally's car is immaculately prepared. If my son and I didn't already own two FE's I would buy his in a heartbeat!
    Sorry to see you leave the ranks of FE's Wally!
    Chet
    FE #22
    Liked: 532
    I can attest everything about Wally's car, setup, prep work, maintenance and care for the car is as good as any pro shop. Helluva nice guy too. GLWTS!
  7. #4
    Plantation, Florida
    Liked: 232
    Default My $.02
    Looking for a FE ? - look NO FURTHER - condition, maintenance, speed etc. are all UNDERSTATED , this is your car PERIOD !
    PS: OK Wally tell all - were are you and your "hot shoe" headed ............. ?
    Senior Member Zambo's Avatar
    Allentown, PA
    Default Wally's Car
    I do all my own maintenance and setup. The car has been meticulously prepared thru out the years which my fellow racers throughout the country will attest to.
    I would have Wally prep my car ANY day of the week. To say his level of preparation of a car is "professional" or at a "professional level" is a vast understatement. Candidly, he's got everything; I mean everything.
    Car was setup for 6' and 5' 6" drivers. I'm 200 lbs and can make minimum weight.
    Wally is a tall guy, consummate gentleman and one of the most generous human beings that I know. He is one of the reasons that I am in this class. He is also one of the reasons I made it to the grid on several occasions.
    He is absolutely correct. 100% correct. You can go out and check every other ad for an FE. You can compare the price of spares and other package. Go ahead; get your calculator and crunch the numbers. It is still exactly what Wally says it is.
    It's a steal. An absolute, unadulterated steal.
    Wally, I just hope that you see the light and reconsider so I can get out there and race with you some more. I'll miss you out there. Don't be a stranger my friend.
    Zambo
  10. #6
    Seminole FL
    Thanks guys for the recommendations. Brandon has talked me into switching to a SFR Gen3. I think he is trying to make it easier on me.
    Wally
  11. The following 4 users liked this post:
  12. #7
    Plantation, Florida
    Liked: 232
    Default ...
    "... But Brandon, where are the wheels ?
  13. #8
    St Cloud, Fl
    Liked: 136
    Quote Originally Posted by Wally O View Post
    Wally
    Wally,
    Looked to me like you worked more on SFR3 at the turkey trots then you ever did on the FE.
    I know the real reason is so you can buy all new toys to work on the car with.
    john
  15. #9
    Classifieds Super License dsmithwc04's Avatar
    Indianapolis
    Liked: 178
    What is the Comprent a-frame setup jig?
    I race communist race cars.
    "Smokey, this is not 'Nam. This is bowling, there are rules." - Walter Sobchak
  16. #10
    Seminole FL
    It is a setup tool used for having repeatable heim settings of the a-frames.
    Wally
  17. #11
    Indianapolis
    Liked: 178
    Oh, gotcha. I read A-frame and went of on a tangent in my head.
  18. #12
    Seminole FL
    Default Fe 14
    Car is sold
  20. #13
    Naples, Florida
    Congrats on the sale Wally. Where is the car going?
    Chet
  21. #14
    Senior Member SStadel's Avatar
    Scales Mound IL
    Liked: 218
    Coming to CenDiv. The more the merrier!
    Competition One Racing
    racer6@mchsi.com
  22. The following 4 users liked this post:
  23. #15
    Senior Member Mick Robinson's Avatar
    Melbourne, Fl
    Liked: 16
    Steve, I have a very low time FE car ( 5 events) for sale. If you need any more for your series, have them contact me at robinsonms@cfl.rr.com.
    Thanks, hope you and all of your series participants have a great 2016 season!!
    Mick Robinson
    FE 017
    Mick Robinson
  24. #16
    Scales Mound IL
    Liked: 218
    Or you could come up here and run the series yourself Mick! I know a shop where you can keep the car
    I will keep it in mind. There is a lot of interest right now.
    racer6@mchsi.com
