Results 1 to 8 of 8
    Vancouver BC
    Liked: 473
    Default Where to go for unusual rod end sizes?
    In specific, my steering arms use a 1/4" bore, 3/8" shank rod end at the steering rack end.
    Anyone know where to ask for such?
    Liked: 958
    Alan,
    Averill and Pegasus carry oversize shank rod ends, but double check dimensions. Usually a 3/8x24 shank will have a 5/16 bore.
    Another alternative would be to press a bushing into the bore to size it to what you need.
    Good luck.
    Vancouver BC
    Liked: 473
    Alan,
    Believe me: I've checked. In fact, I just checked again. It's a 1/4" bore with a 3/8" shank
    But I can't press a bushing into a bore to make it larger in diameter, Dan. I wish I could.
    Good luck.
    Thanks, but I think I now know what I've got and what I need.
    A closer look shows that the ball has been ground/file/machined on both mounting faces. I just check the Aurora Bearing website, and what I've got is an HXAM-4 (or equivalent); a high misalignment rod end that's been modified to reduce the ball width from 0.593" to 7/16". Everything else matches up: head thickness, overall length, etc.
    Mystery solved!
    Paso Robles, CA
    Liked: 287
    Very strange, in my reality, a 1/4" bore is smaller than a 5/16" bore. This is pretty standard in our race cars.
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    kea
    Vancouver BC
    Liked: 473
    A 1/4" bore is smaller than a 5/16" bore, David.
    I've got a rod-end with a 1/4" bore held in a clevis with 1/4" holes by a 1/4" bolt. How is pressing a sleeve going to help?
    Liked: 3326
    By allowing you to use a much more standard 3/8 shank x 5/16 bore rod end with a 5/16 -> 1/4 reducing sleeve (as long as the 5/16 ball is not too wide).
    Vancouver BC
    Liked: 473
    That's a possibility I'd missed
    Duh.
    mukwonago, wisconsin
    Liked: 96
    Can't see the forest through the trees. Happens to us all sometimes.
