Page 8 of 11 FirstFirst ... 4567891011 LastLast
Results 281 to 320 of 429
  1. #281
    Apache Junction, Az
    Liked: 102
    The answer to our question is here:
    http://www.apexspeed.com/forums/showthread.php?t=12877
    Then look in the classifieds for the appropriate ratios for your transmission.
  2. #282
    Senior Member Dave SanF 50's Avatar
    Alameda in SF Bay area (CA)
    Liked: 34
    It really helps to know your R&P ratio. Either a 10:31 or a 9:31
  3. #283
    Tacoma, Washington
    Liked: 210
    Quote Originally Posted by mkp250r View Post
    ....I have Citation with a kent 1600 with hoosier r45's Thanks guys
    I'm gonna guess if it's a 'classic' it's 9:31
  4. #284
    Ann Arbor, MI
    Default Road Atlanta Gearing on Dunlops
    Hey Guys,
    Ex Spec Miata racer here getting ready for the mitty. Have a '78 FF with the treaded dunlops anf if I get the car ready, this will be my first race with it. Assuming I have the 9:31 R&P in the gearbox.
    Can someone please give me a good ratio starting point for the track??
    Larry
  5. #285
    New York
    Liked: 157
    Hi Mike,
    What are your lap times compared to the pole? I wont try to dissuade you from trying to find the optimal gears for every track, but the honest truth is that unless you are running close to the front, you can pretty much use the same gears for each of the tracks you listed. They are all within a tooth for each gear which wont make much of a difference if you are still working on your driving until you are looking for that last couple of tenths.
    For example, you could run 24/26 4th gear at each of those tracks (exception might be WG where you might use 24/28.
    Whenever we went to a new track, we would run our "Watkins Glen" gears to start and in the end might change up or down one tooth on a couple of gears.
    Obviously if you are bumping up against redline in any gear you would want to change but the difference that a tooth makes is not much.
    HTH
    Tom
    PS, where are you in New York? We are on Long Island.
  7. #286
    Sarver, Pa
    What trans do you have ? if it's a Mk5, I have a box full of good gears, If it's a mk8-9, I have an almost brand new set of 23-27m gears I would like to sell. Pops
  8. #287
    Pittsburgh, PA
    Default Gearing for Montreal
    Probably already been answered, but I couldnt find it. Does anyone know the gearing for a 9:31 R&P club ford at Circuit Gilles Villeneuve in Montreal?
    Thank you!
  9. #288
    ny
    Liked: 14
    Hi Mike,
    HTH
    Tom
    This will be my first time out in this car. We are going to test at lime rock on the 21st of April. I think we are only really off on our 4th gear.
    I don't want to buy anything until we really have me up to speed and the car some what failed in.
    I'm located in dutchess county ny about 30 min north of white plains
  10. #289
    Apache Junction, Az
    Liked: 102
    Default Never been there, but….
    Quote Originally Posted by Cass Racing View Post
    Thank you!
    The Arizona group that goes to Montreal each year runs these:
    Montreal
    1st 18:33 1.833
    2nd 21:30 1.429
    3rd 23:27 1.174
    4th 25:26 1.04
  11. #290
    Liked: 1117
    I got a better pull out of the hairpin with a shorter first, so with my 9:31 ran
    17:35
    20:31
    23:28
    25:26
    Any kind of a draft and you'll need every bit of that 25:26. A case could be made for slightly taller or shorter third gear because 23:28 often exceeded our 6500 redline on the short straights. I'll probably not change the selection this year, though.
  12. #291
    PA
    Default Gearing for Indy
    Hi
    I'm looking the recommended gearing for the INDY roadcourse as well as the oval for CF.
    Anyone who went to last years Inaugural event have the info.
    I am running a 9:31 ring and pinion.
    Contributing Member cgscgs's Avatar
    Indianapolis, IN
    Liked: 39
    Default Indy
    Having no idea what to run last year, I used M-O gears because they were in the box. Turned out fine, I don't plan to change them this year. 9:31 box, CFF on Dunlops:
    20:32
    22:29
    24:27
    26:26
    Seeya there,
    Chuck Smith
  14. #293
    ny
    Liked: 14
    hi,
    Since I'm not able to run any majors just yet bc this is my first year. Looks like my first race weekend is going to be FRCCA weekend at Pocono south east course.
    Does anyone have the gearing for pocono south east course?
    Im running a FF 84 Citation, Hoosier r45, Mk9 Trans
    Am i Correct that bc i haven't run a certain amount of regionals i cannot not run any majors?
  15. #294
    colorado
    Default Indy Gear Ratios
    I will be traveling to Indy for the Vintage Event on the new road course. Does anyone know what gear ratios to use in a Club Ford using American Racer slicks with a 9:31 R & P? Thanks for any help.
  16. #295
    Hudson, Ohio
    Liked: 208
    Are slicks allowed in SVRA FF? I know that our vintage FF car must run treaded tires and I believe that all FFs are the same. No?
    We ran at Indy last year and all FFs had treads.
    Ralph Z
    1968 Alexis Mk14 Formula Ford
  17. #296
    Powhatan, VA
    Liked: 143
    Is a 1:1 fourth too tall with Dunlops and a 9:31?
  18. #297
    colorado
    Default formula Ford gear ratios
    My car is a 82 Lola 640. SVRA put it in the Post Club Ford class and they allow slicks. I recently received an e-mail from them telling me that class is already full at Indy and I am on the list if there is a cancelation, so we will see. Thanks again.
  19. #298
    Hudson, Ohio
    Liked: 208
    Thanks for the clarification.
    Ralph Z
  20. #299
    San Diego,Ca
    Liked: 493
    I think the slicks they want you to run are Hoosier 60's. Try 17/34 first, 25/27 top.
    Roland Johnson
    San Diego, Ca
  21. #300
    colorado
    Default Indy gear ratios
    Thanks Roland for the gear ratios. This will be very helpful going to this new track.
  22. #301
    ny
    Liked: 14
    Default The Perpetual "What Gearing Do I Run at This Track?" Thread
    Anyone have the gearing for Thompson with a 10:31?
  23. #302
    Ann Arbor, MI
    Liked: 49
    Default Anyone run NCM Motorsportspark have any thoughts on gearing?
    I'm planning on running my CFF there in a few weeks, and I'm looking for ideas on where to start for gearing. Specific suggestions or comparisons with other tracks are welcome.
    Phil
  24. #303
    Ann Arbor, MI
    Liked: 49
    Default M-O gears?
    I'm thinking of starting out with Mid-Ohio gears. Anyone have any other suggestions?
  25. #304
    Liked: 611
    Default NCM gearing
    As you haven't heard from anyone else yet, it looks like we now know who to ask about gearing after you return !
  26. #305
    Ann Arbor, MI
    Liked: 49
    Yeah, that's kinda what I'm concluding, too. Oh well, somebody has to do it...
  27. #306
    Liked: 611
    Default NCM gears
    At least with you, I feel we'll get some good numbers !
  28. #307
    Liked: 435
    What is the date of the race at NCM? I have run my 7 there, great track but I can't help on the gearing.
    Graham
  29. #308
    Ann Arbor, MI
    Liked: 49
    June 13-14, Cincy region.
  30. #309
    Liked: 435
    Cool, I will try and be there..... as a spectator
    Graham
  31. #310
    Liked: 860
    Maybe Barber-ish gears might work ok although NCM may have a higher top speed:
    17/35 19/32 21/30 22/28 10/31
    (Haven't been there, just thinking out loud)
  32. #311
    In PFM at NCMMP, I hit 135mph in 3 places. three slow corners around 45mph. Avg speed for the lap was 86mph.
    At Barber, same gearing (PFM short stack), I hit 125mph and slowest corner was 49mph. Avg speed for the lap was 86mph.
    YMMV!
  33. #312
    Sequim, WA
    Liked: 46
    Default Curious
    To far to drive, but what does NCM initials stand for and where is it located? How come we don't hear or know much about it? What are you driving? Hope that you do well and good luck!
  34. #313
    Quote Originally Posted by Albatross View Post
    National Corvette Museum Motorsports Park. New 3.2 mile track, 23 turns, built across from the museum in Bowling Green, KY. Just opened fall 2014.
  35. #314
    Liked: 860
    Just entered, thanks to help from fellow TN racer Earley Motorsports! Thanks Graham!
    Phil, hopefully we can pit close. I haven't been there before but my coworkers were there this weekend for a ChumpCar event. Hopefully I'll get a good report from them!
  37. #315
    Ann Arbor, MI
    Liked: 49
    Garey,
    Any word on how complete the facilities are? My wife just told me I'm in trouble if we're looking at Nelson Ledges level facilities. I just can't imagine Corvette guys accepting that, though.
  38. #316
    Liked: 860
    They just opened last fall so building isn't complete. the NCM website has some info and I've never been to Nelson Ledges. I know the black stuff is complete and that's enough for me! (Plus, I bought a used motorhome so my boys will be comfortable )
  39. #317
    Ann Arbor, MI
    Liked: 49
    Default National Corvette Museum Motorsports Park - CFF
    Mid-Ohio gears worked pretty well. With a 9:31 axle ratio, I ran
    20:32
    22:29
    24:27
    24:24
    The slowest corner would benefit from a lower first gear, but it's a short run from there to the next braking point, so I think I prefer the taller first where it helps launch onto the second long straight. I think I got over 6500 rpm at the end of the third 'straight', but that's not a good place to be looking away from the track as it's a blind 4th gear sweeper.
    edit: This is for the 3.15 mile Grand Full Course
  41. #318
    Classifieds Super License andyllc's Avatar
    Columbia, SC
    Liked: 201
    Default Sebring 12 hour course
    Looking for Sebring gears for the long course. I have a 10:31 but I can do conversions if anyone has the gears for that track and with a different diff. Thanks!!
  42. #319
    NW Colorado
    Liked: 30
    Default Arroyo Seco
    Anyone have anything for Arroyo Seco?
    John Mihalich, Jr.
  43. #320
    Reno, NV
    Liked: 30
    Default Thunderhill East
    Mid May I will be taking on my first race with the FA, any gearing suggestions for the 5 speed at Thunderhill?
    Julian
