I was letting the car idle while measuring the idle lambda reading to confirm it was working and found my CDS copilot to report that the WBAF-2 was giving me a reading of .8 volts at idle. This equates to 11.8 lambda. The motor was warm and water temp at aprox 165F. I think that is slightly more rich than I would prefer but wanted to see what you guys were measuring.
Also, how loud are the valves on this motor while idling? With the motor idling and warm there is some valve tick about the same level as a midyear Miata with the "HLA" tick. Wanted to confirm this is normal as I can't remember hearing it the first time I idled the motor before taking half the car apart to go do a thorough check of the car since it is new to me.
