Hello all,
Finally back stateside and working on my Zink restoration again.
Little background, purchased a Zink a while back and have been slowly preparing it for vintage FV racing when not deployed.
I've recently run into an issue of fitting the fan shroud and charging system.
The fan shroud was making contact with the rear support bars for the main hoop. I did a little hammering to an old damaged shroud and managed to get enough clearance as shown in the below pictures.
Now however, I've see to have discovered another issue. When mounting the generator, the pulley and shaft isn't going to clear the firewall, seat belt mount, or original throttle cable pivot point.
I am aware I'm using a 12v generator which is a little longer than the original 6v generator, but even using an offset pulley will cause the belt to make contact with the throttle cable pivot point when lined up with the lower pulley.
From the other pictures I've seen of Zinks online, there should be no need to clearance the fan shroud to clear the frame tubes and while a tight fit, the generator pulley should have no issues clearing the firewall area.
I'm currently taking a step back to figure out the space issues. Is it possible the engine mounts are spacing the entire engine/transaxle too close to the firewall? I do know they are not original.
My current solutions include either rebuilding the engine mounts (worried about clearance between the top of the transaxle and trapezoid) or installing spacers between the frame and trapezoid (little nervous about the frame strength with this idea)
Any suggestions?
Thank you,
George
