Page 1 of 2 12 LastLast
Results 1 to 40 of 51
    Senior Member Doug Fisher's Avatar
    East Marion NY
    Default '84 Swift DB1- SOLD
    1984 Swift DB1 for sale. SOLD
    Heading for Club Ford......
    $18, 500.00
    Frame up restoration 2012.
    Chassis done by Pat Prince.
    [[/I]
    Fox Shocks with droop limiters.
    Several Sets of Springs see below.
    spare sway bars, see below.
    Protec Bell Cranks
    Refurbished Fuel cell with baffle
    Stack Dash
    Cockpit adjustable Rear Sway Bar
    Z Bar rear Lower Control arms.
    New Front suspension.
    Virtually all new Rod ends.
    Floating rotors.
    4 lb Lithium Battery with charger
    Refurbished Fuel cell with baffle.
    19 Wheels
    15 gear sets.
    Spare fitted Nose.
    New tail and nose- CCE composites
    3 spare engine bay body work
    Marcovicci Engine
    Misc. Spares.
    6 sets of Springs: 300, 400, 375, 250, 253. 378. In car 275 and 425 I believe.
    4 spare brake rotors
    3 spare front sway bars
    Front rockers spacers (2)
    Upright bolts
    Steering rack bushings
    5 Rear Lower Control arms
    1 front lower Control Arm
    Front rocker (right or left)
    Engine bay brace
    Rear Suspension Shears plates
    4 Brake Calipers
    Starter with gear
    Spare Misc Half shaft stuff
    2 brand new half shaft without CV joints
    Spare Wiring harness
    wheel spacers
    Skid Plate
    3 front Uprights one needing repair
    2 Rear Uprights
    Original dask, analog tach
    10 original Swift wheels
    9 panasport wheels
    Linden, Ca
    Liked: 25
    Default Stang
    Actually, I'd like to hear more about the 'stang parked next to it!
    East Marion NY
    Original Shelby.
    Linden, Ca
    Liked: 25
    Default I had a sense it was something special
    Chicago, Illinois
    Quote Originally Posted by Doug Fisher View Post
    9 Panasport Wheels
    10 'Original Swift ' wheels
    19 wheels? So that's one set on the car, 3 spare sets, then 3 more loose wheels?
    I'm assuming this thing is turn-key, ready to rock? Log book included and passes tech?
    East Marion NY
    Many log books covering its long Hx.
    Tech, no issues.....car is as in the photos, clean.
    It is essentially 'turn key', perhaps other than fitting ones self into it .....
    and, there is a set of Hoosiers R45's with one or two cycles on 'em purchased in October....they'd be a fine way to start a test day in the Spring or in Florida....
    East Marion NY
    acoupla more photos.
    Senior Member Derek Holmes's Avatar
    Liked: 78
    For anyone looking at this DB1. I have raced against this car and it is well prepped and very clean. It has allot of updates, the Prince lower arms make a difference in DB1 handling. If I had the money Doug I would buy your car! I hope to see you next year back on the track.
  13. #9
    East Marion NY
    Another picture....
  15. #10
    Senior Member Pi_guy's Avatar
    New York
    Liked: 229
    Well prepared car, maintained in a professional shop.
  16. #11
    Sunny Scottsdale
    Hours on engine?
  17. #12
    East Marion NY
    about 7 more likely 8 hours following complete rebuild.
  18. #13
    Sunny Scottsdale
    Doug, I sent an email to the address you have registered with Apex Speed, did you receive it? Mark
  19. #14
    East Marion NY
    photo of chassis ....
  21. #15
    East Marion NY
    Mark, check your email.
  22. #16
    East Marion NY
    more photos
  24. #17
    Circuito Do Sol Portugal
    Liked: 384
    Is Bellof's car yours.
    Lucky SOB.
    Sweet ride....
    Maris Kazia ,CEO
    EuroKraft Inc Racing
    Circuito do Sol
  25. #18
    Plantation, Florida
    Liked: 232
    Default Difference from stock ......
    Quote Originally Posted by Derek Holmes View Post
    ...., the Prince lower arms make a difference in DB1 handling. ....
    Front and/or rears ? ..... I see the fronts have anti intrusion bars any other modifications ? IF the rears, I can see how they are designed (I opine) as able to adjust camber and toe easier but why a difference in handling ? They appear to operate in the same plane ? Is the rear/lower pick-up point different and a part of a "kit" ?
  26. #19
    Liked: 78
    I have just the front Prince arms on my DB1. I noticed a difference in the braking zone. You do not get the flexing in the arms like the stock DB1 arms. My car also seemed much more stable in high speed turns. I only have the front arm upgrade. With the rear the car would feel even better in my opinion. I have had 2 guys that know more about DB1's than I could ever know highly suggest the upgrade.
  27. #20
    East Marion NY
    Kazis 31....
    The 956 is beautiful.
    I would rather have the 917 K out which is out of the picture, frankly speaking. I achieved 'check 'off my a bucket list when I sat in it to assist in a brake bleed.
    I have picture.
    df
  28. #21
    East Marion NY
    Swift 17.
    The rear Zbars are robust.....
    more appropriate for battle perhaps and it may be that the grip is better on less than smooth surfaces ... less flex....I dunno.
    Very easy to do bump steer .....
    The front lower control arms are also stronger....thicker aero tubing. The anti intrusion bars are nice to have.
    I do believe the car has a better feel under 'heavy' braking (Summit Point ) , however, I am old and two spins away from senile.
    Call Pat Prince. He built them. Very nice work.
    He did the chassis as well, also very nice work.
    Derek gits that Swift of his 'round Summit very well BTW.
    DF
  29. #22
    Liked: 78
    Thanks Doug! If I could just keep the car on the track without spinning I may be able to have a decent finish... Its all part of my strategy so drivers dont get near me lol.
  30. #23
    Liked: 384
    Doug.
    You can still check it off your bucket list.
    RCR in Michigan Make mean 917 kit.
    Check it out.
    Maris Kazia ,CEO
    Circuito do Sol
  31. #24
    Global Moderator DB4 Tim's Avatar
    NM
    Liked: 24
    Doug is it still for sale?
  32. #25
    East Marion NY
    yes !
  33. #26
    New York
    Liked: 229
    yes !
    Thought so Numskull xiv and my snap on dealer spent about 15 minutes looking over your car on Saturday. It made a nice discussion piece. It looks very nice.
  34. #27
    East Marion NY
    Thanks.....
  35. #28
    Bradenton, FL
    Liked: 14
    Quote Originally Posted by Pi_guy View Post
    Great looking car! Lots of nice go-fast bits.
    Jon Updegrove
    RF97 Van Diemen FC
  36. #29
    Austin, Tx
    can anyone comment on the cost or complexity of widening the roll bar supports in order to fit a larger driver for this car?
    How much room do you get?
    How would it compare to other FFs for cockpit room with or without modification?
  37. #30
    New York
    Liked: 157
    Quote Originally Posted by autodoctor911 View Post
    If you are asking about making the cockpit wider at the shoulders, I seriously doubt you could modify the frame around the rollbar. I have never seen it done on a DB-1. Everything is really tightly packaged in that area. If it can be done it would not be an easy thing to do.
    The most common DB-1 frame mod and the only one I have seen to gain some room in the cockpit is to "bend" the middle horizontal frame rails in the cockpit, this will give you more room for your lower arms and hands and make it easier to shift and steer.
    As far as comparing Swifts to other cars, DB-1s are very tight, especially in the shoulders but also for the legs and the feet. Tall drivers can fit, but not if they are built like a football player.
    HTH
    PS: Doug's DB-1 is top notch and very well maintained at a race shop 5 miles from my home. Anyone interested should have no concerns about buying this car.
  38. #31
    S.P.I.R.
    Default DB1 cockpit mods
    We have modified 2 DB1 chassis to fit larger than designed for drivers . The trick is to get the driver's shoulders down below the top horizontal tubes , this can be done by manipulating the junction and angles where the tubes meet around the shoulder area . Plus more room can be gained by re-profiling the fuel cell cover , re-locate shoulder harness mounts , re-profiling the top half of the NACA / radiator duct . I'll try to post pictures but if anybody is interested email me . steve@auto-spa.com
  39. #32
    NM
    Liked: 24
    As tight as a DB4 ?
    HTH
  40. #33
    East Marion NY
    Tom,
    Thanks for the kind words...
    Hope someone finds that the car suits them....
    Doug
  41. #34
    East Marion NY
    Still for sale.
  43. #35
    Contributing Member Brian331's Avatar
    Middlefield, Connecticut
    Liked: 128
    A super clean and well maintained car! I Would personally by this car from Doug, if I could still race that is, but it's sadly not in the works!
    A great car for a starter!!
    Former FF #31,
    East Marion NY
    Brian,
    Thanks for the 'plug'.
    I hear through my 'sources' that your eye surgery went very well....
    great news !
    Merry Christmas to yawl.
    Doug
  45. #37
    Arizona
    Liked: 324
    Default Location of car
    Your profile shows you are in East Marion, NY. Is the car located in this town also or somewhere else?
  46. #38
    East Marion NY
    cgoffroad,
    I apologize for not responding to your question.
    The car is located about 60 miles West from here, about 45 minutes from NYC on LI New York.
    Doug
  47. #39
    East Marion NY
    Default Price Drop
    Price lowered to to $17,500.00.
  48. #40
    NM
    Liked: 24
    BUMP.....
    Quote Originally Posted by DB4 Tim View Post
    As tight as a DB4 ?
