Results 1 to 15 of 15
    Ramsey NJ
    Liked: 23
    Default Hewland Gearbox Vent Fitting
    The brass vent in my Hewland end cover is loose. The threads in the aluminum have stripped due to use over the years during gearing changes. It is currently a oil pressure line fitting, so I don't have to unscrew the fitting from the rear cover. I could go to a larger fitting, but I'd rather not. Does anyone know of a better solution, maybe something with a locking nut for inside the cover?
    It's not how fast you go.
    It's how well you go fast.
    A "solution" is staring you in the face
    Replace the fitting with an aluminum fitting welded in place.
    Liked: 909
    or attached with some really good epoxy.
    Liked: 123
    Plug it and drill a 1/16" hole in the cover over on that boss above the shift finger so oil isn't thrown at it by the rotating nuts. You win the prize for the most welded on rear cover for a Hewland, mind you...
    Ramsey NJ
    Liked: 23
    I can't weld. I'd have to find someone to weld an aluminum fitting on it for me.
    The boss above the shift finger looks as though it already had a vent hole, but has been filled in.
    That's the way I got that cover. I do have a spare one. It has had some repairing done also, but looks better.
    Since you aren't the one with the welder...
    Remove the cover, clean it extremely well and JB weld (epoxy) the current plug in place. Let cure completely before you re-install.
    Tacoma, Washington
    Liked: 210
    ......JB weld (epoxy)....
    The magic drug.
    Mn
    Liked: 202
    Some how JB Weld & the J.C. Whitney catalog just go together in my mind. I keep both in the same tool box drawer.
    Liked: 123
    There is also a Loctite thread restore goop that would work.
    Ramsey NJ
    Liked: 23
    I figured out a solution after I looked at one of my fuel jugs. A used tire valve, a thin one w/o the core. One rubber grommet below the nut and washer. This is my spare cover with the vent hole in the boss above the shift finger.
    Mn
    Liked: 202
    Great idea !
    Contributing Member Blah's Avatar
    New Zealand
    Nice, what psi do you run in the Mk9?
    Ramsey NJ
    Liked: 23
    I match the rear tire pressure for better balance.
    Be sure to use Nitrogen or Argon for minimal pressure growth!
    Apache Junction, Az
    Liked: 102
    No, use helium to shift weight to the front tires.
