CAR SOLD. Thanks all.
Car raced at Thompson June 7th successfully. I'm trying to get it on track for next months Thompson date, but life continues to intervene.
The full list of stuff for sale is at the bottom, the price is all in, I will parse it out to a limited extent, like the trailer and spare motor if people are interested enough and I have solid leads on the car. The 2006 Grand Cherokee Hemi is up for grabs after the car and trailer are gone. But the heart of the deal is:
$9500
2002 Red Devil
3 sets of wheel, 2 slicks, 1 set of wets, all used
spare Rotax 494 motor
12' Haulmark enclosed trailer, 7' high, very roomy
electric car lift (powered by included car battery)
fiberglass body strengthened and painted, new body fasteners all over
tons of spares...
https://www.dropbox.com/sh/utzfnvmgruuscjh/trDv8TfUho
Stuff I've added on is on top, 2nd chunk was the package sold to the gentlemen I purchased the car from, and the 3rd chunk was the spare package that the previous owner contributed. The car was a steal when I got it, considering its better off now than when I got it, the next owner is getting a great steal too.
Schumacher Battery Charger
Fire Engintuisher (New)
Longacre Tire Pressure Guage
2 Metal Jerry Cans
~6 gallons of VP 110 Octane
Quicklift Jack
Blue and Clear Racer Tape
Sparco Arm Restraints
Zip tie assortment
Motul 660 Brake Fluid
1 Bottle Water Wetter
1 Bottle Engine Ice
Upgraded Axle
Solo Bleeders
New Tie Downs
Pedal Covers
GoPro Hero 2 w/ Roll Bar mount
1 used 2002 Red Devil F500 race car complete *
1 2007 Haulmark Transport Deluxe custom ordered 12x7 enclosed trailer *
1 set(4) mounted Hoosier rain tires(used) *
1 set(4) mounted Hoosier racing slicks(barely used with about 1 heat cycle) *
1 set(4) mounted pit tires(currently on car) *
1 spare mounted trailer tire(new) on white rim *
1 spare Red Devil Nose (painted to match car)
1 installed AMB hardwired(I believe it is the non battery modal,Ed can concur) transponder *
1 complete Red Devil front left or right corner suspension(disassembled) *
1 short steering shaft,currently installed in car, 1 long shaft *
1 spare axle(new) in box *
1 complete Digatron MDL Dt-54k RMT4 with associated parts and instuctions,cable,installed in car *
2 Jack stands *
1 red air tank*
1 6ft long electric lift w/ 12V battery *
1 installed electric winch w/ wired remote in trailer
6 new qts Belray racing oil *
1 just opened qt Belray racing oil *
1 30deg layback, barely used HANS SPORT H&N restraint with additional sliding tether *
1 spare coil *
1 spare CDI box *
1 spare fuel pump *
1 spare solenoid,used *
1 spare solenoid, brand new *
2 sets used brake master cyl kits with spare parts *
2 used Wilwood brake calipers *
2 used MIkuni VM 38 carbs(condition unknown) *
3 used batteries(condition unknown) *
1 box suspension parts(which includes the above mentions front spare suspension) *
1 large drive gear *
2 small drive gears in box,clearly marked for use at NHMS *
1 box w/various clutch covers?,misc parts *
1 box used spart plugs and rubber box contained carb jets *
1 used starter *
1 Polaris primary clutch with electric start ring *
2 Skidoo primary clutchesn 1 with eklectric start ring *
1 Rotax 494 exhaust manifold *
1 car tarp *
1 rear diffuser *
8 trailer tie downs(attached to the D rings *
2 plastic ramps *
2 hip cushions for car(in trailer) *
2 sets used Hawk Blue brake pads *
several boxes used bearings *
1 new radiator cap *
1 original Digitron box with various pieces inside *
1 Spare Rotax 494 engine
1 Polaris primary clutch without electric start ring
1 spare Mikuni fuel pump
1 small tackle box,various clutch weights(many)
1 complete Rotax 500 cyc head cover
1 new book Olaf Aaen clutch tuning performance
4 new engine drive belts
1 Rotax 494 Yellow engine cover
1 spare Rotax water pump(cover?)
4 new clutch tuning springs
3 used clutch tuning springs
1 used spre Rotax exhaust manifold
1 box of 8 brand new NGK BR9ES spark plugs
5 different clutch helix's for performance tuning
1 box new exhaust manifold springs
