An oil / coolant heat exchanger will work nicely here.
If you want to look at an example, take a look at what Mike Devins did on my car. Go to Post 48 (also #10-17 on Page 1) http://www.apexspeed.com/forums/show...t=51114&page=2
I believe that there is something from the early days that said when these motors get hot they will then blow up next run. If your oil gets to hot then the motor is junk.
Listen to those who have suffered through the developement process in the class....and do what has been shown to work. Go for the largest oil cooler you can fit in the sidepods....same for the radiator. Experimentation here can be costly.
These engines are as much oil cooled as water cooled (due to gearbox friction...and also due to spraying the bottom of the piston with oil to cool the piston which helps control the flame spread in the combustion chamber.
Plumbing for one each rad and cooler is simple and compact as well.
Jerry Hodges
JDR Race Cars
In the spirit of "Design by Fire" , throttle cable needs rerouted away from header heat.
(You guys are getting A #1 advice here!)
O'Connell
Car looks absolutely amazing.
I find that it makes me a bit crazy to read all about open wheel heroics when I'm without a car so just saw the post tonight.
You're going to LOVE driving the Mygale. In the FC form it was a perfectly balanced ride that was completely predictable.
Sean O'Connell
1996 RF96 FC
1996 RF96 FB
2004 Mygale SJ04 Zetec
The pics of the A-arms make them appear to be CF or at least a CF look. I believe we are required to use steel or ferrous metals.
“THE EDGE, there is no honest way to explain it because the only people who really know where it is are the ones who have gone over.”
Hunter S Thompson
Gee take it easy on me guys. I'm a little familiar with what these engines need. We ran a full house Suzuki GSXR 1000 for 5 yrs in a DSR. Both the rads and oil cooler are from the FC and are just sitting there to see how everything is going to fit. I really don't want to start messing with the side pods shape to fit in a bigger rad so I just might go with 2 like it was but with a larger oil cooler.
Crew chief for Dave O'Leary
N.E. div National Champ
FF FM CSR DSR
You did a great job on your rebuild of this car I looked at all the pictures, the Mygale
looks like a very strong chassis and we thought it would make a GREAT F1000, FB.
everything on the car now is new, brakes package, all lines, engine, dash, exhaust, shocks updated, fuel pump, diff, chain, so we are looking forward to driving it soon.
thanks
dave
Just some side comments from the recent pics :
1. it looks like the swirl pot is possibly lower than the highest water passages on head. Call george dean and talk to him about this. Gary Hickman or John Labrie in their phoenix car just had to deal with this being an issue.
2.shorten the exhaust tailpipe if you can. it has been proven on the dyno the extra length tailpipe does hurt HP.
Hello Guys
last night was our first test since we built the car, we tested at PIR and put around 50 laps on the car it ran GREAT, one concern we had was oil temp, seems high compare to what I had on my DSR 280 degrees,
What kind of oil temp is safe??
SPECIAL THANKS TO TOM ASHBAUGH AND DAVE SMITH FOR ALL THERE WORK AND EFFORT TO BUILD THIS GREAT CAR!!!!
Awesome job dude!!
Which side of the cooler is that temp taken from? That will tell us if it's getting too hot or if it's ok.
I've been told by one engine builder you want to know how cool the oil is going in and another says you want to know how hot it is coming out. If you can collect data on both that helps. One builder tells me if you saw the temp coming out it will scare the hell out of you.
Gary Hickman
Edge Engineering Inc
FB #76
Hi Gary
The temp is taken from inside the oil pan itself, that is where I have always taken it?
That wouldn't be my choice on where to sample oil temp. I prefer to either have it on the inlet to the cooler or the outlet.
My initial reaction is 280 seems high in the pan but maybe not.
Gary Hickman
FB #76
Congratulations on getting it on the track.
If you are still using the oil cooler/radiator arrangement from post #36, you need to get rid of the second radiator and put in a much larger oil cooler. A much larger portion of the cooling in a motorcycle engine is done by the oil than in a street car. One radiator is plenty.
Talk to your engine builder about where he wants you to measure oil temperature and then measure it there. 280 in the pan sounds really high.
I'm not an expert on the class, but if you ran brief testing sessions at BeaveRun (in Northern PA) during the last week, that will be about the coolest temperature values you will ever see. The engine does not know if it is in a DSR or FB, so assuming you measured oil temp in the pan on the DSR, comparing values is valid, and probably more relevant than to other FB cars.
Congratulations on a successful conversion!
Your oil temps are too high. We always measured oil temp in the pan on our Piper. We NEVER saw over 250 deg F. on the hottest day, usually much lower. Get a bigger oil cooler
We also take our temps in the pan.....and again 250 is about tops.
The oil in the pan goes through the pump, then the filter, then the cooler.....so it is as hot as it will get in the pan.
Jerry Hodges
JDR Race Cars
get those oil temps down or you will be buying engines instead of oil coolers.
Maybe go back and read post #41 and #45.
Then read what Coop said in #46. You are getting great advice here.
I agree that our oil temp was on the high side and at the same time water temp was 145 too low. we did replace the oil cooler that was in previous pictures with a large one. But my concern has been it has been it is partially blocked with the second radiator. I'm going to remove it and run with just one rad. next time. hopefully raise water and lower oil temps.
After 2 test sessions and 2 regional races. I am happy with the car so far. Oil temp problem seemed to come from the by pass hole in the engine had not been blocked. All the oil was not flowing through the oil cooler right. It is now. I do have temp sensors on both in the pan and out from the cooler. Looking forward to next year.
Crew chief for Dave O'Leary. NE Nat.champ FM,FF,CSR,DSR.
Cool Mat Pat
704 662-9099
Thanks, Steve
I am jealous Dave. Best of luck with the car.
PS-are those car show pictures at Ross Park mall?
Hi Bob
I have tested the car but have not raced it yet, we are leaving today for Summit
Point and then if everything goes well we will be trying to race it enough to get to the runoffs in Daytona.
The car was in the mall in Indiana Pa, that is where the crew chief and crew lives so
they like to show it off there.
hope to see you in Daytona in the fall
take care
dave
