Results 1 to 9 of 9
    Manitoba, Canada
    Default Clutch disk thickness
    Hello,
    Can anyone tell me what the thicknes of a clutch friction disk is when new ?
    I'm refering to tilton or quartermaster disks.
    Have several on hand that appear only slightly used..wanna see if they are scrap or i can get more time on em.
    Pittsboro IN
    Liked: 282
    Approx. .103"
    Liked: 611
    Default clutch disk
    AP Racing (which has a better center hub) starts the same.
    Be sure to check the pressure plate for taper while you have it apart
    Manitoba, Canada
    Ah, Thanks Guy's.. Looks like I have a couple of usable spares..I will check the pressure plates out as well.
    Reagrds
    Tom
    Manitoba, Canada
    One more thing..Can the presure plates be cleaned up on a lathe if they show wear or taper or are they scrap ?
    Liked: 929
    There is a minumim thickness specified at least on the Tilton install instructions.
    Not sure of the top of my head, but they do say that it is ok to resurface them down to a certain minimum thickness.
    Also, I would recommend surface or blanchard brinding unless fou can get the ring on the side towards the springs to seta against t=some flat square point on your lathe chuck.
    Sequim, WA
    Liked: 46
    Post
    .125 on my 2 race old disk. Check that splines are not pointed, as in worn. Teeth should be flat.
    Liked: 1495
    also check for cracks radiating from the circular voids at the ends of the slots. I never noticed them until I cleaned off a disk with brakleen and the combo of the solvent and carbon made a good dye penetrant.
    Manitoba, Canada
    Hey Thanks Guy's for all your valuable input..
    I have plenty to look at then but seems I will be able to save a few bucks by refurbishment of these spares..
