    Contributing Member CJD's Avatar
    Winter Springs, FL
    Default RF 96 Brake Bias knob
    Does anyone know what brand Van Diemen used for the brake bias adjustment knob and cable? My car has the orange knurled knob. I've been unable to rotate the knob without a pair of channel locks even after lubing the assy at the knob. The pedal end looks fine and doesn't look to be the issue I suspect I will need to replace the components and want to do a simple R and R. Thanks for any info.
    Destin FL
    Liked: 649
    Take your pick here, or give Brad Baytos a call at Primus if you want a replacement of the original.
    Winter Springs, FL
    Default Brake Bias Adjuster
    thanks Rick, the assembly finally loosened up. No need to replace now. I Guess it just needed to soak.
    FYI, Primus in now gone. All their inventory was bought by the old Transatlantic folks up in Ga. Not sure what the Baytos boys are doing now. The Cape folks that worked with Primus now run Cape Motorsport out of St. Pete and are teamed with Wayne Taylor Racing.
    Destin FL
    Liked: 649
    Quote Originally Posted by CJD View Post
    FYI, Primus in now gone. All their inventory was bought by the old Transatlantic folks up in Ga.....
    I just spoke with Brad, AND PRIMUS IS ALIVER AND WELL, with a full inventory.
    Incidentally, he has new and original brake bias cables on hand.
    Winter Springs, FL
    Default Primus
    Rick, do you have contact info?
    Destin FL
    Liked: 649
    Here you go:
    Full inventory as seen here, cell is (727) 804-7417.
    Winter Springs, FL
    Default Primus
    Thanks man.
