Motorsports Southwest is now proud to be offering the next generation custom seating solution that replaces two part foam and bead seats.
MSSW offers the EIS SFI 45.2 Foam Seat Kits to the club racing community.
This is a much quicker easier system to make a custom seat than either 2 part foam or bead processes.
Advantages over 2-part foam or beads systems:
- EIS conforms to SFI 45.2 standards
- The curing is rate is slower than 2 part and provides the driver more time to position in the seat
- The curing rate is MUCH faster than a bead seat. Sitting time is less than 10 minutes.
- No vacuum required
- No noise to deal with
- No high temperatures generated like epoxy can do
- Easy trimming
- No messy beads or bead residue all over the shop
- EIS initially flows in every space around the body and then expands, making a highly conformal insert. Much more conformal than beads.
- EIS does not require replacement after impact.
- The kit is slightly more expensive than a bead kit but when factoring in your time and aggravation and the SFI approval you will find it is less expensive overall.
You can make a seat in 20 minutes and have it trimmed and covered in a total time of 1 hour.
Contact Motorsports Southwest for more details, a brochure and pricing information.
info@motorsports-sw.com
