Page 7 of 11 FirstFirst ... 34567891011 LastLast
Results 241 to 280 of 429
  1. #241
    Contributing Member Brad Smith's Avatar
    Kelowna ,BC
    Liked: 49
    Thanks Trout
  2. #242
    Sagle, Idaho
    Liked: 180
    Thanks Trout, see you over there.
    LH
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  3. #243
    Kelowna ,BC
    Liked: 49
    Default Buttonwillow 14 CW
    Can anyone supply a starting point to gear Buttonwillow 14 CW for a FF1600 10:31?
  4. #244
    Senior Member Ed Erlandson's Avatar
    Burbank, California
    Default gears at Buttonwillow 14
    17/35
    20/32
    22/30
    24/28
    there are several variations one tooth up or down
    running American Racers the cornering speed is lower and the gears are likely lower as
    16/34
    19/32
    21/29
    21/25
    have fun
  5. #245
    Chico, California
    Liked: 31
    Default 2014 Fontana gearing for FF?
    Looking for FF gear ratio recommendations for Auto Club Speedway/Fontana. The newest response I have found on this thread for "Fontana" is 8 years old, no results when searching on "Auto Club Speedway". The 8 year old results are:
    20/30
    22/29
    21/24
    25/25
    Are those ratios still applicable?
    I have an RG98K Van Diemen, Ford motor, LD200 gearbox, frankly can't remember what the final drive ratio is but most LD200 equipped FF's have been the same, its the other ratio from the common MK9 Club Ford ratio, been a while since I ran this car.
    Thanks in advance.
    Tom Duncan
  6. #246
    SoCal
    Liked: 102
    A better way to describe the gearing for a particular track is to just post the maximum speed in each gear, assuming no tire growth with speed to keep it simple. Stating it that way includes all of the other effects, such as rev limit, tire diameter, and final drive ratio. With that information, any racer can do the math to select ratios for their car given their particulars.
  8. #247
    Leominster Ma.
    Default NJ Lightning
    Can anyone pass along the gearing for NJ Lightning coarse ? Honda with a 10:31. I'm thinking something close to Limerock ?
    Thanks Lenny
  9. #248
    Contributing Member cgscgs's Avatar
    Indianapolis, IN
    Liked: 39
    Default Indianapolis Motor Speedway - road course
    I never thought I would have to ask this question: what gears for the road course at IMS? (Mk9 with 9:31).
  10. #249
    Brighton, MI
    Default Gingerman
    Gingerman gears FF ??
  11. #250
    Denver
    Quote Originally Posted by cgscgs View Post
    Who is putting an event on at IMS??!
    Mike Green
    Piper DF2 FF
  12. #251
    machesney park,il
    SVRA.
  13. #252
    Senior Member GAC's Avatar
    Peoria, IL
    Liked: 91
    With a 10:31 and standard size rear tires, my Gingerman gears were 18:34, 20:31, 22:30, and 23:29.
  14. #253
    Indianapolis, IN
    Liked: 39
    Thanks for the bump Mike Green. Since its just down the street I decided to apply to run in the Indy SVRA event, and to my surprise was accepted (as a Club Ford).
    I hope someone will have a suggestion regarding gears, maybe someone who ran at Ontario many years ago and still has their notes. There is only one really slow turn (behind the museum), followed by a VERY long stretch at full throttle. Seems like most of today's rovals have a lot more than 9 degrees of banking so I'm not sure what track might be similar. Maybe Pocono?
  15. #254
    Peoria, IL
    Liked: 91
    I would start out with Daytona gearing and go from there.
  16. #255
    Indianapolis, IN
    Liked: 39
    Default Gingerman
    Last year (my first time at G'man) I ran 20:32, 21:30, 23:28, 25:26 with a 9:31. I wrote in my notes that second was too low so this year I'll try 22:30.
  17. #256
    Indianapolis, IN
    Liked: 39
    Default IMS
    Not getting any replies to my inquiry about gears for IMS, I used Mid-Ohio ratios...mainly because that's my next race. Mostly I just wandered around the track, trying to find the line, and sometimes trying to find the turns! (mainly 1 and 7). 26:26 turned out to be fine for fourth, I hit 6500 rpm at the end of both straights which was enough for me.
  18. #257
    Contributing Member Tigaman's Avatar
    Virginia Intl Raceway
    Liked: 67
    I used Road America gears to put my old Tiga on the Sports 2000 pole at a high 1:37.
    Worked well for me...
    -Peter Krause
    1984 Tiga SC
    www.peterkrause.net
    "The Driver is the Greatest Performance Variable in the Racing Equation"
  19. #258
    Member NoLimits's Avatar
    Bluffton, SC
    Default Barber Motorsports Park Gears
    I plan to attend the 45th anniversary event at Barber. I've never been there and have no idea what gears to run. I have a 1984 Swift DB1 Honda with a Hewland gearbox MK9 9.31. Any help is appreciated.
  20. #259
    Vancouver BC
    Liked: 473
    Default Gears I used at Pacific Raceways, June 13-14
    After doing my research and looking at my available inventory of gears, I equipped my Van Diemen RF89 (9:31 final drive) with
    Used (For next time)
    16:30 16:30
    20:27 19:27
    24:28 24:28
    25:24 24:24
    Overall, I think the gearing was close and if I'd been able to get a slightly higher entry onto the straight AND if I'd been using the tail bodywork (not yet modified for a new exhaust mount), I might have been able to make use of the overdrive top gear. As it was, I was getting 6500 RPM at the end of the main straight.
    And second gear should have definitely been 19:27, it was just too big a jump from 1st to 2nd for the 3 to 5 straight, and I'd have gotten better acceleration from turn 5 to turn 7 as well.
  21. #260
    Michigan
    Liked: 28
    Default Waterford Gear Ratios
    Would appreciate recommendations for Waterford gearing. Have searched but can't find anything.
    Crossle 35f
    10:31 R&P
    Dunlop FF Tires
    I have the ratios from Lamonts book but am wondering what you veterans like to run there.
    Thanks!
    Mike
  22. #261
    Midland, MI
    Default DB1 on Hoosier's
    From my notes :
    Swift DB1 w 10:31 and 22.5 rear tire diameter (speed at 6800 rpm)
    1st : 17/34 (73)
    2nd : 19/33 (85)
    3rd : 20/31 (95)
    4th : 21/29 (106)
    Take care,
    Chris Pruett
    Swift DB1
  23. #262
    Liked: 611
    Default Waterford gear ratios
  24. #263
    mi
    Liked: 25
    Default waterford gears
    I have a 9:31 R&P
    does anyone have those gears?
  25. #264
    Liked: 611
    20/31
    21/29
    23/28
  26. #265
    Arlington, Texas
    Default Gears for Barber Motorsports Park
    Anyone got starting gear set for Barber? Never been there.
    Thanks Mike Sauce
  27. #266
    Liked: 435
    I have heard similar to Laguna Seca if that is any help.
    Graham
  28. #267
    Arlington, Texas
    Thanks But I have never been to Laguna so I still need info.
  29. #268
    Cumming, GA
    Liked: 215
    I haven't run an FF there yet, and if I did I don't know how relevant the Honda gearing is (I tend to like to keep them well off the rev limiter on the straights).
    If you can track down any gearing for Carolina Motorsorts Park it should be pretty close, although Barber has more fast turns than CMP and fewer "creepers".
    In the Mazdas take the hairpin at 40-45 mph (slowest point on the track), and I don't think we saw a top speed above 128 with the wing angles we run there.
    Sam Lockwood
    Raceworks, Inc
    www.lockraceworks.com
  30. #269
    Contributing Member Bernard Bradpiece's Avatar
    Annapolis, Maryland
    Liked: 182
    Default Barber gears
    Mike
    Don't know if this is a help. I've been once in 2010 with Merlyn 11a. Was the one of the quickest VFF on the North East Coast back then. Could not get the gears right at the time but I noted that if I went again to go a bit lower and try:-
    9:31
    23" diameter tires (Dunlops)
    18:33
    20:31
    22:29
    21:25
    Not a lot of straightway - front straight is the fastest, the back section is fast but up and down and several fast 3rd gear sweeping corners. 4 or 5 critical slow corners that need a good exit and good acceleration out for a decent lap time. If you are in a modern car you might want to start a tooth higher for the extra cornering speed.
    Let us know how you fare.
    Best
    BB2
  31. #270
    What is the top speed of a good FF at Laguna?
  32. #271
    Geneva IL.
    With a 13/36 I'm going to start with these ratios.
    1st 16/34
    2nd 17/30
    3rd 20/30
    4th 22/29
    Ed Midgley
    ser
  34. #272
    Geneva IL.
    Also I'm running a Honda. 6750rpm redline.
    Ed
  35. #273
    Arlington, Texas
    Guys- Thanks I think I have a ball park to start with.
    16/35
    18/32
    20/30
    22/28
  36. #274
    Vancouver BC
    Liked: 473
    Mike, do you also have a 13:36 final drive, or do you have something taller yet?
  37. #275
    Arlington, Texas
    Default barber mtsps
    10/31 ring and pinion
  38. #276
    Vancouver BC
    Liked: 473
    Then you need to use taller ratios that were recommended for a 13/36, not shorter.
    Take the ratios given by Ed Midgley and divide larger by smaller (34/16 = 2.125)
    Multiply by 36/13 (2.125 * 36/13 = 5.885)
    Then multiply by 10/31 (5.885 * 10/31 = 1.898).
    Then figure out which gear set most closely matches that number. In my collection, that would be an 18/34 first.
    If you use a different red line, than the Honda that Ed has, then multiply by your redline and divide by his to get the change in ratio. (1.898 * 7000/6750 = 1.969) Assuming you're shifting at redline of course.
  39. #277
    Senior Member Scotty Segers's Avatar
    Keller Texas
    Default Laguna gears
    Would anyone like to share Laguna Seca gears for a Honda powered Van Diemen with a 10/31 R&P
    Scotty Segers
  40. #278
    Geneva IL.
    I just got back from Laguna. I have a 13/36 ratio so I won't confuse you with actual ratios. Gear for 75mph in first and 121mph for fourth. I was geared for 70mph in first and it was too low. I have a Honda engine also.
    Ed Midgley
    PS The track has no grip in the afternoon when the sun is on it. It's a little better in the morning with clouds.
  41. #279
    Keller Texas
    Thanks Ed
    Scotty Segers
  42. #280
    ny
    Liked: 14
    Default Need Help Buying Gear Sets
    What gears are you guys using at:
    LimeRock
    Watkins-Glenn
    Njmp (lighting)
    Njmp (thunder)
    Summit Point
    VIR
    thompson
    Does anyone have any used sets i can buy, that are in decent shape.
    I have Citation with a kent 1600 with hoosier r45's
    Thanks guys
