I need a set of exhaust headers for my 82 van diemen FF1600. I have heard from hy tech and universal racing services. Are there any other sources? I am in Phila/S jersey area
Try the people at BAT, Peter or Erik @ (941-355-0005) in Florida. They have a good and affordable exhaust system that I believe will fit your racecar and they are supporters of the FRCCA.
nothing in their catalog matches my headers. Headers are beside cyl. head and valve cover,but not above. Completely enclosed by engine cover.
Sounds like early Citation headers. I got a spare set. Ooops sorry, mine are for Pinto.
Try this guy: www.hytechexhaust.com. John builds the best systems.
I have this set available. They are off an 81 VD but from the pics I've seen they appear to be the same as 82.
$ 250.00 plus shipping if you are interested.
Can build you a performance system. Check out www.roxannesheaders.com
I had JR make a set of stainless headers for a customers Ralt Rt-5. Both the customer and I were pleased with his work.
I have an excellent set of Swift-style Hytech headers, but they won't clear the factory body.
Not a problem... I can build a custom set... Need some photos/measurements. The set that you have marked with points of interference also makes fabrication easier. Most of my systems are stepped stainless steel, but your option.
Gordy's RF81 headers will fit. The rear bodywork on the RF81 and RF82 are identical. Only the rear suspension changed. You will save a bunch of money!
- Frank C
