    OH
    Liked: 60
    Default Torque Spec & Brake Fluid
    Does anyone know the proper torque the wheel nut should be tightened on a VD FC?
    What is the correct/ best brake fluid to be used?
    Liked: 1494
    'bout 100 ft lb.
    there will be all kinds of opinions, but I've found the most cost effective solution with a decent heat resistance is ATE blue.
    Liked: 3323
    Default Castrol/Girling LMA
    That's what I use - inexpensive, easily available, easy on seals, and no temperature problems.
    OH
    Liked: 60
    Default Thanks
    Thanks guys for the info!
    OH
    Liked: 60
    Dave,
    I finally got the car complete. Just a few more adjustments to make. Hence the posting. I just want to make sure I get it right. It's come a long way since you have seen it.
    Jerry
    Liked: 3323
    Quote Originally Posted by glm34 View Post
    Dave,
    Jerry
    Great! Good luck!
    Liked: 923
    So Jerry, When is first race??
    Always want more winged cars out there.
