Results 1 to 11 of 11
    Albany, NY
    Liked: 238
    Default Protective Film?
    Just installed new bodywork. There's an area down low that takes a lot of punishment from rocks, etc. The previous bodywork was protected there by 6 or 7 strips of "helicopter tape". But the tape looked awful after years of abuse. And it was almost impossible to remove.
    Does anyone have any ideas on a better way to protect bodywork from stones, etc? Is there a protective film that is easily changed and/or doesn't yellow over time?
    Thanks for any ideas.
    Chatham Center, New York
    Liked: 863
    Helicopter tape works better than anything else I've ever used. Take it off with a heat gun (actually a good way to put it on as well) and loosen the residual glue with either BrakeClean or WD40. It does need to be replaced every once in a while.
    Midland, MI
    Default Leading Edge Tape...
    I use black "Leading Edge Tape" for a few things...
    Works great and does not yellow...
    Chris Pruett
    Swift DB1
    Albany, NY
    Liked: 238
    Thanks Bob. I don't know how long the helicopter tape was on because it was already there. Considering that the previous owner was in his 70s, I figure it was there a long time. It had yellowed badly and was pock marked badly. And neither a heat gun and WD40 could remove it. Didn't try brake clean.
    Albany, NY
    Liked: 238
    Pru, the leading edge tape is the same thing as was I was calling "helicopter tape". Since there are graphics at the spot I was talking about, I'd be using the clear version.
    But I was hoping someone might know of something that is more easily removeable.
    Or perhaps I could put some clear tape on the adhesive side of the leading edge tape (adhesive to adhesive) but leave enough adhesive around the edges for adhesion to the fiberglass?
    Potomac, MD
    Liked: 45
    I recommend 3M polyurethane protective tape:
    http://www.aircraftspruce.com/pages/...iveLeading.php
    Liked: 923
    I also use the black leading edge tape.
    Tougher than nails.
    A bit hard to get around compound curves without slitting it.
    Sticks well to a clean prepared surface.
    Can paint it with Krylon Plastic Kote (sp) paints and the paint holds up reasonably well, if you don't like the black.
    3M now makes a spray can protective film that dries completely clear. Peel off later without residue. Of course they advertise it for your favorite sports cars against road debris and grime, but maybe an extra coat or two would make it thick enough for race track use.
    Austin, Texas
    TracWrap is a temporary protective vinyl. It is inexpensive and easy to work with. It will last about 4 weekends or more. Comes in tape widths or up to 18". Peels off easily when you want to change it.
    Dean
    Wolf GB08
    Austin
    www.motorsports-sw.com
    Albany, NY
    Liked: 238
    The tracwrap may be what I've been looking for.
    Thanks everyone.
    Austin, Texas
    If you use the code MSSW when you check out, you will get a discount.
    Dean
    Wolf GB08
    Austin
