Some of you may have noticed the Formula Continental rule stating that fasteners are unrestricted, except for those 1) connected with any moving part of the engine or 2) supporting the intake manifold. I could understand the 1st exception, but not the 2nd. I thought that perhaps someone had used plastic bolts to reduce heat transfer into the manifold, they melted, and the manifold/carb fell off and started a fire.
Well, there's an interesting "Rule Proposal - hardware" thread under "Rules Discussion" on the Formula Ford Underground forum that explains the history of the rule. Apparently some years ago, a few engine builders began using intake manifold bolts with reduced shanks to allow better alignment of the manifold with the head. [Scott Rubinzer: Was your ~'88 Runoff qualifying time in FF really tossed out because of this?] Formula Ford has the additional problem that you can't even access the stock bolts and risk leaks and crossthreading on their 1600 motors. So ...
1. How many drivers even know what a stock original intake manifold bolt looks like? I'd bet that at least half of a typical FC field could be protested because of non-stock intake manifold bolts.
2. The intake manifold bolt exception is not specified in the F2000 Pro rules. Do you think any of the Pro cars change their intake manifold bolts when they race against us?
3. The rules allow much $$$ to be spent porting the head and reshaping the intake manifold ports, but not four simple bolts that allow alignment of the manifold and head ??
Frankly, I think this is a silly rule. Formula Continental and Formula Ford are just that: formula classes, not spec classes. We should encourage reasonable innovation, and the cost of four non-stock intake manifold bolts seems not unreasonable.
Comments? Does anyone want to propose that this exception be eliminated?
Randy
BTW, Formula Ford Underground is at http://server5.ezboard.com/bformulafordunderground.html
