I've seen the dual ride height adjusters on a couple cars now, and the explanation I was given once of being able to independently adjust each side makes sense, but they also said it probably just makes whole setup more complicated for the average racer.
I guess I am curious as to what the rest of the FV world thinks of them. Are they worthwhile on a beam-type suspension? I have a beam I will be adding adjustment to, and am thinking about doing 2 on the top while I'm at it.
Also, of the 2 styles of adjusters, what do you recommend & why? I only have experience with the serrated/straight knurl, and I know it can't really be adjusted without disassembling the front end to relieve tension before breaking the adjuster loose. The other type looks to be easier to work with.
Thanks!
