    Classifieds Super License Skelly's Avatar
    Clovis, California
    Liked: 82
    Default Honda install for VD
    I am in the process of installing my honda fit into my 99VD in the car in a few weeks and could use some help with pictures of the water tubes. The manuel does not show to much other than the pipes installed on the engine itself. Could any e-mai mel pictures of there water pipes after install, and should i install them before or after the engine is bolted up. Any help would be great.
    Thanks Apexspeed members
    Sean Kelly
    sean1882@att.net
    Senior Member LenFC11's Avatar
    Houston TX
    Liked: 212
    sean
    [FONT=Verdana]install water pipes before putting engine in chassis.. make sure you cut the silicone hose a little long to accommodate as needed.[/FONT]
    Cheers
    Len
    Porsche River Oaks. Houston
    Clovis, California
    Liked: 82
    Thanks Len
    These pics will help me a lot. Hope to have it in the car by end of OCT.
    Thanks Again
    Sean
    Fallbrook, N. San Diego Co.
    Quote Originally Posted by Skelly View Post
    Thanks Len
    Thanks Again
    Sean
    Making progress?
    US
    Quote Originally Posted by LenFC11 View Post
    sean
    Helpful indeed! Yep, I'm also eager to see the outcome of yours Sean!
    Clovis, California
    Liked: 82
    Default Honda Install
    Hi All
    Just a quick update. Installed wiring harness, top intake, and rough fit of water lines. Coming together slowly. Will post pics of the engine tommorow. Just need more time in the day to get everything together.
    Sean
    Clovis, California
    Liked: 82
    Here are some pics of what i have done so far. If anyone sees something that does not look right, please let me know before i install engine next month. Thanks everyone for there help.
    Sean
