Results 1 to 12 of 12
    Forum Advertiser Dale Carter's Avatar
    Mokena, Illinois
    Post
    I need some advice on removing the fuel cell on a '99 Van Diemen chassis. I have the "Y" brace removed and the inspection cover off. What's next?
    Thanks, Dale
    Dale Carter
    2003 VanDiemen FE #29
    Life is Good
    Plano Texas
    Post
    Only done this once. I think that we just gave up and took it out the bottom when the floor came off.
    Contributing Member Steve Thomson's Avatar
    Minneapolis, MN
    Post
    I did it once. I took all the foam out, then it will collapse enough to get it out the hole.
    Steve Thomson
    Owner/partner
    ZSports Midwest
    steve(@)zsportsmidwest.com
    612.964.9572
    Mokena, Illinois
    Post
    Are you saying I can get the whole cell out through the 4"x6" inspection hole? Yipes!
    Dale Carter
    Life is Good
    Senior Member Daniel's Avatar
    SC
    Post
    Remove the radiator. Drill out the rivets holding the lower front cover (the panel with the inspection hole) to the cell enclosure. Slide the panel out the side of the frame. Now, with the lower half of the X-brace removed, you can work the cell out of the opening. When re-installing the cell, a liberal coating of baby powder on the outside of the cell makes it slide back in much easier. Hope that helps.
    Mokena, Illinois
    Post
    Thanks for all the replies. Dale
    Dale Carter
    Life is Good
    SC
    Post
    Ooops, forgot something....loosen or remove the cockpit side bodywork so that you can slide that cell enclosure piece out.
    Senior Member Scott Gesford's Avatar
    harrisburg, pa
    Post
    How do you get the Y brace off? Or should I just take the floor off?
    harrisburg, pa
    Post
    Anybody?
    Ann Arbor, MI
    Liked: 49
    Post
    The 'Y'-brace is just bolted in at each leg end. One vertical bolt going down right in front of the middle of the fuel cell, and two going up through the floor angling inboard. Floor panels bought from Van Diemen have access holes already there. If you don't have them, it would be pretty hard to locate where to drill such a hole. Unfortunately, pulling the floor is not a trivial task since putting it back together requires a lot of riveting and some epoxy to do it right (see previous threads on floor replacement).
    Mokena, Illinois
    Post
    Scott, check for the holes in the belly pan. If you don't have them I can take some measurements off of ours. I put our bare chassis up on high horses over the weekend so it would not be a big deal to get them for you. If you a are careful with a drill and open the holes up with a die grinder, you should be ok. Dale
    Dale Carter
    Life is Good
    harrisburg, pa
    Post
    Thanks Dale. I'll look at it again this weekend.
