I'm installing a replacement engine in my Vector FST after the first engine dropped an exhaust valve and I have couple of questions (next time I'll make better notes before I pull the engine).
Upon installing the replacement engine I noticed that the clutch throwout bearing was contacting the clutch. I've now adjusted the linkage so that there is the smallest amount of free play (as best I can tell) at the actuating arm. Is this a good setting?
What's the firing order on the engine and how are the cylinders numbered?
What number main jet and spark plugs are folks using?
Thanks in advance,
Lance
