Home
ApexSpeed Portal HomeApexSpeed Reader GalleryApexSpeed.blogsApexSpeed AdvertisingForums
Go Back   ApexSpeed > Formula F > FF: Club Ford
Reply
Thread Tools
Old August 21st, 2012, 4:06 AM   #1
Hawke
Hawke's Avatar
Default Formula Ford - Exhaust Design
I'm sure this has been asked before, but I cant find any reference to it.
What is the best sizing of pipe diameter and primary length? I am getting a new one made, and would like to get it right.
Hawke is offline   Reply With Quote
Old August 21st, 2012, 8:05 AM   #2
Oooh, scary question! Art, who used to post here fairly often, did some research on the ideal header and it was pretty complicated. On the other hand, 1.5" primaries between 29" and 31" long into a 6" to 8" collector, with a 24" to 36" long secondary has worked for many years. Smaller diameter and longer primaries bias towards lower rpm peak, larger and shorter primaries bias towards higher rpm peak. Beyond that you get into tri-y collectors, 2 into 2 into one systems, stepped primaries, anti-reversion cones, and unequal length primary designs.
OTOH, if you aren't perfecting your tune to match your header on an engine dyno, it really doesn't matter all that much....
Brian is online now   Reply With Quote
Old August 21st, 2012, 11:49 AM   #3
stephen wilson
To add to that, Primaries smaller than will be giving up H.P.
stephen wilson is offline   Reply With Quote
Old August 21st, 2012, 4:59 PM   #4
Hawke
Hawke's Avatar
Brian,
Thanks for that. I'm sure those sizes will work for a 56 year old driver of a 40 year old car. That extra 1 or 2 HP, isnt going to propel me to the front of the pack.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
©ApexSpeed 2000-2013
