Home
ApexSpeed Portal HomeApexSpeed Reader GalleryApexSpeed.blogsApexSpeed AdvertisingForums
Old August 6th, 2012, 5:48 PM   #1
Earley Motorsports
Earley Motorsports's Avatar
Default Lotus 61 Shifter or Similar Photo
Seat is in now for the shifter. Does anyone have a photo of the lower attachment point of the shifter. I have one of the top but I cannot see where the bottom mounts to. Any help would be greatly appreciated. After that, onto the brake pedal, finished the clutch and throttle pedals and half the steering column over the weekend. Slow but making progress. And for those keeping track, all the suspension is done and it has been on it's wheels and rolling.
Thanks for any help, Graham.
Earley Motorsports is offline   Reply With Quote
Old August 7th, 2012, 12:09 PM   #2
gord leach
gord leach's Avatar
I'll try to get You a picture after work when I get home
__________________
later Gord
BTW...only toilets need doors
www.blurredvisionracing.com
gord leach is offline   Reply With Quote
Old August 7th, 2012, 6:57 PM   #3
Earley Motorsports
That would be great Gord. Appreciate the help.
Graham.
Old August 7th, 2012, 8:30 PM   #4
scorp997
scorp997's Avatar
try race-cars.com in the 'sold' area... they have a lot of pictures that are useful
http://race-cars.com/carsold/lotus/1...75638626li.htm
http://race-cars.com/carsold/lotus/1...97891934lt.htm
http://race-cars.com/carsold/lotus/1...54158016lt.htm
__________________
-John Allen
Tacoma, WA
'72 Royale RP16
scorp997 is online now   Reply With Quote
Old August 7th, 2012, 8:46 PM   #5
Earley Motorsports
Thanks John, it is where the bottom pivot part is that I need to see. I had looked at all those and even just about had my nose on the screen but I still couldn't see under those frame tubes . Yes that sold section has been very helpful. Thanks though.
Graham.
Old August 7th, 2012, 9:41 PM   #6
scorp997
scorp997's Avatar
I took my novice day in a 61, but I don't remember anything too special about the shifter.
IIRC, the main shaft is pulled/pushed/rotated concentric with the upper bushing (as you probably know) and the lever bottom protrusion slides left/right (shaft ratation) between two plates spaced out from the cowl bulkhead. You can see these plates and their mounts at each end of the plates in the pictures.
hopefully one of the other guys can get you some good photos soon. good luck!
__________________
-John Allen
Tacoma, WA
'72 Royale RP16
Old August 13th, 2012, 6:19 PM   #7
Earley Motorsports
Default Thanks
I have made my shifter thanks to the explanations. I thought it was on a spherical beering or something at the bottom but then it would not slide left and right. Anyway, thanks, it works fine. Actually pretty simple when you look at it.
Graham.
Old August 13th, 2012, 8:31 PM   #8
scorp997
scorp997's Avatar
glad it worked out.
My Royale has 2 spherical bearings (one mounted to the bottom of the shifter and one on the frame) that allows the sideways movement.
__________________
-John Allen
Tacoma, WA
'72 Royale RP16
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
©ApexSpeed 2000-2013
