I don't know if this is the right forum but nothing else looked appropriate. We use a MK9 gearbox and SWEPCO 201 gear lube. I was advized to stay away from Redline when I started running the hewland so that is the reason for SWEPCO. Anyway, we have a helluva time with gear selection after gear changes when the box is cold. Seems to get better once on the track. I "lubricate" with the SWEPCO when I assemble. No obvious wear problems with using the SWEPCO stuff.
Is there a better gear lube to use? Should I use a different lubricant during assembly?
Milt McPherson
