Anybody have four (4) of these?
ON THE SHELF AT GTP
781-393-6887
603-370-0746
BILL STEPHENS
GTPRACE@COMCAST.NET
Is there anyone with the 'raised nose' willing to take a few photos of this on the car?
- How do they mount to the chassis bulkhead?
- Can I presume one set holes are for the crush box and the other are for mounting the nose piece?
My cars all loaded in the trailer but here's how they mount.
The brackets mount to the frame in the orientation you have in the Pix. That would be the way the right side upper and lower brackets would mount. There ARE 2 Left's and 2 right's.
The Allen head bolts that mount them to the front of the frame go thru the holes in the right of the Pix.
The countersunk holes are for the van Diemen crush box. The 4 ears of the crush box fit Inside these brackets.
The threaded holes are for the allen head bolts that mount the Nose to these brackets.
As the Van Diemen frame and body parts can have a lot of,ahh. "Production Variables" you may have to put some thin washers between these brackets and the frame to get the right clearence for your combination of parts.
If you are buying a New never mounted nose try to get one without the 4 mounting holes pre drilled. That makes locating them for your "Application" a lot easier.
You need to have all the related parts on the car at the same time to Juggle the clearences. That includes Body side panels,cockpit cowl,shock cover and nose. (ask me how I know)
Darrel;
As I visited with Bill Stephens, I am trying to make a silk purse out of a sow's ear with an RF-94/95: RSF's raised nose, Pennon's Polecat diffuser and Rennie Clayton's Aero package.
- Are the mounting holes in the chassis bulkhead prepared? Say, CrMo inserts welded and ground flush at both fore and aft bulkhead surfaces with an ID to accommodate the block mounting bolt?
- What is the vertical separation between the nose piece mounting holes, center to center?
I'm leaving for a race and should be back on Tuesday. If you want to call me then my number is 510-825-2737 Darrell
Rick
first of all there is NOTHING WRONG with a RF95 car !! really enjoyed mine !!! updating it is not a bad thing either the RF95 car did a lot of things right on the track .. not at ALL tracks but VERY quick at alot of them
My Zetec is in the trailer but accessible ... if I get home while it is still light .. I can take some pix and measurements for you .....
let me know if you still need them ..
you have my email I believe
Greg
friend us on FaceBook search "velocity haus"
like on facebook search "velocity haus Engineering"
Velocityhaus.com
velocityhaus@gmail.com
@Velocityhaus2 instagram
Greg;
Thanks, Bud.
Rick,
Four photo of my Rf2000
Last edited by Ken Lawrence; 09.17.09 at 1:51 PM. Reason: only got one photo first time
I'll try again three photos
Ken: You're the MAN!
So is there anything inside the nose that fits into the block mounting bolt holes?
Rick,
Nothing inside, attached photos show inside top and bottom and outside
Ken
Ken;
Thank you for making my problem, your problem. I owe you a couple of cold Rolling Rocks.
Fellas;
As you maybe aware, I'm rebuilding my car. Anyone have four (4) spare mounting blocks as pictured in the initial post?
VR
