Since I am restarting this project. Here are some images. The first is of the 2007 GSXR in the frame with front mounts done (they are adjustable in all degrees of freedom at least for now). You can clearly see one of the four bosses where the original bellhousing attached. I plan to work with only those four points for attaching the back of the car
2nd picture is with the spacer frame started. Copious triangulation still needed. And behind the spacer is the LD200 modified casing that is a chain drive version and will take all of the original VD pieces for suspesnion mounting except the lower front A arm clevis which mounts to the spacer since it used to bolt to the belhousing plate. Third picture is the nose and splitter. Not at all like the 96FC.
Fourth shot I have added the VD aluminum casting that braces around the oil tank, bellhousing in the FR and also carries front top A arm and shock. The cross bar that holds the bellcranks simply bolts on as well as the cross bar that holds the upper rear A arm point. If you look carefully you should be able to see all of the pickup points in this and the final photo
