FM parts assortment, all parts used unless noted:
Mk 9 layshaft
Steering U joint
Front upright pin
Ackerman Plates, (4) new, (2) used
Ackerman block, new
RARB pushrod, new
Rear wing mount spacers between Mk9 rear cover and wing uprights, not used on all FM's IIRC
(2) LH large heim joints / radius arm
(4) RH large heim joints / radius arm
(2) single adj damper top perches
(2) single adj damper bottom perches
(3) single adj damper bottom perch lock ring/jam nuts
$275 + shipping from 30076
Left Sidepod $150
Can tote these bits to VIR in a few weeks for the Double SCCA Nat
PM me, Thanks
