Wondering how they make carbon fiber control arms. This is a statement from Honda F1:
The composite component is laid up in two half moulds which are
bolted together prior to the curing operation. Two thin strips of woven composite (oriented at ±45o to the axis of the tube), known as joining plies, are used to form a “strapped butt joint” in order to bond the two halves together. The tube and joint are consolidated in a single operation by the insertion of a pressure bag (@7bar) and heat in an autoclave.
Question: When is the “strapped butt joint” applied, before or after the two halves are cured?
I have an actual carbon fiber F1 control arm and there is no sign of any strips on the leading or trailing edges. The weave on the part is one piece starting and ending at the trailing edge.
