Im in need of a Penske racing shock 8100 or 8300 series for a Adams Arrow Formula Vee rear zero roll suspension. Used is fine as long as it's in perfect working order. Please call Alex Rizer at 1-540-272-7802
I have four 8100s for sale. Twenty minutes from a fresh Anita Milican dyno. How many and what size?
How much are you wanting to sell one of those shocks for?
Being new to fv's could any explain to me what the different sizes mean. Do the sizes vary by the make of car?
thanks
FVs (actually any car) require different length rear shocks depending on the design of the rear suspension. The 15 1/2" (extended length) shock is very common as it is used on most cars with trailing arms behind the rear axle. This would include Mysterians, Caracals, Adams, Stilletos, etc. Also, many of these same cars use a very soft spring and will use a 2 1/2" ID diameter rear spring which seems more stable in its application.
BTW ... I am in the market for a (or pair) 15.5" Penske 8100. Would trade pair for Dynamic pair. See http://www.apexspeed.com/forums/show...703#post276703
What is the typical cost of a Penske 8100, say a 15.5"?
Probably a new one would cost about 1/3 of what you paid for your car. The Fox that came with your car is a similiar performing shock and probably perfect for your immediate needs. I believe Bob Lybarger is a Penske dealer or distributor and has experience with Fox and Penske on FVs. He is also in your area and can evaluate your Fox for you.
A new 8100 will run you close to $1000.
I had a Fox in my old car that was rebuilt using penske internals.
Stimola can do that fior you if you'd like.
A new 8300 shock (old 8100) now runs $850.00. A new spring will cost another $ 75.00. They are radily available. If you need one let me know. Bob Lybarger - LRE,
Lybarger Racing. Phone is 1-815-363-8560 and email is lrefv2@earthlink.net.
Bob Lybarger/Lybarger Racing/LRE/Director Area 5
