-- for a GSXR. What capacity is most advisable? Also, has anyone used the following:
OBX aluminum oil dry sump tank. This tank is perfect for those who are building a dry sump system for small engine based projects such as a go kart, motorcycle, jetski, or off-road buggy. The model comes with 4 oil feeds (all male) at the top and 2 oil feeds at the bottom ( 1 male and 1 female) ; 6 total connectors. Oil drain is also located at the bottom, but not seen in the pictures below. This dry sump tank hold approximately 2.5 quarts. The tank also has an internal baffle system and utilizes a 2 piece design. Approximate dimensions of the tank is 11.00" H x 5.00" W.
It's an Ebay item, and beautiful for easy packaging in the chassis. But. Is it large enough?
Thanks to all ---
Chris Crowe
