Is there anyone out there that can help with a problem I'm having with my Suzuki powered race car (2008 GSXR 1000 motor)?
The problem I'm having is when I stand on the throttle between aprox. 5,000 RPMs to red line the engine is misfiring no power, almost like it's on the rev limiter. The engine idles perfect and mid range rpm is great it's only when I get into the upper rpm range it has this problem. One other thing I would add (maybe unrelated) , the Aim dash I have in the car stops working when I run the car up into the rev's.
Things I have tried and am going to try-
1 checked the spark plugs (all hot and good color to them)
2 checked compression in all cylinders (160 PSI)
3 Replace fuel (110 Octane Turbo Blue)
4 Replace main master switch (Hella UL rated Switch)
5 Bypassed the Ignition switch
6 Replaced battery
7 Checked all ground connections
8 Going to check fuel injection system (send out for cleaning)
9 checked color of exhaust tip (good color to it)
10?????????????
I would appreciate any help!
Nicho
