[SIZE=2]
This is an amazing car: Technically truly exquisite, with an incredibly high level of design execution, build quality, safety, and factory support. If you've been around race cars for a while, you'll instantly recognize the profound differences between this exotic, ultra professional package and any other "customer" race car.
What I like most about modern Formula 3 is that second only to F1, it is the highest contemporary formula category in which world class manufacturers like Dallara, Lola, Martini, and Mygale compete directly with each other: Within this competitive market context technology levels are extremely high, with engineering refinement simply not found in one make/spec classes. These are highly advanced, incredibly capable cars which are still accessible at the enthusiast level.
As a testament to the Dallara F300’s capabilities, reference the USF3 qualifying lap record at Sears Point against the standing Formula Atlantic record. Bear in mind that the USF3 VW engine package delivers an understressed 200HP on electronic fuel injection (pectel) versus the Atlantic’s highly volatile 250+ HP.
SCCA FA qualifying record
1:29.317 Keith Lively
USF3 qualifying record
1:29.651 Luciano Gomide
Chassis specifics:
This Dallara F300 chassis #037 is equipped with a low mile Bertils USF3 specification VW engine which runs strong. The chassis was delivered new to the states in 2000 for use in the now defunct USF3 series, and ran only a very limited schedule. It is a pristine, extremely low time chassis/engine, with a truly perfect, never damaged all carbon FIA tub and crushbox. Other notable features include a fresh TRE prepped 5 speed Dallara/Hewland transaxle, Koni 2812 MKII shocks, fresh AP twin plate 5.5" clutch, monster Brembo brakes, and Pi2 data. The fluids, pads, battery, and hoses are all new/fresh, with Willians belts good until 2008. The chassis has been SCCA homologated, and has the SCCA specification roll hoop, fuel port, and ID certificate. It is exceptionally clean, and has just been set up, shaken down, and completely race prepped.
Depending on engine displacement, (1835cc or 2000cc) it is eligible for SCCA’s Formula Atlantic and Formula "S"…or a myriad of "historic" sanctions.
Spares:
Wheels/tires
Speedline magnesium wheels: 2 sets in addition to those on the car (3 sets total) - all in new or near new condition - One set with scrubbed Avons, the other with new sticker Kumhos.
Transport wheels: complete set including hubs, wheels, and tires – excellent.
Gears
MK5 gears: 27 sets in addition to those in the car (32 sets total)
Bodywork: all with fresh paint to match the silver/anthracite scheme on car.
Front wing main plane - carbon
Front wing endplates
Front wing mounts – billet
Front wing mount fairings
Nose cone/FIA crush structure – carbon/honeycomb
Rear wing endplates
Underbody splitter - carbon
General
Jabrock chassis plank - new
FIA Rollhoop
Half shaft/CV assembly - complete
Front upright/hub assembly
Front tie rod
Eibach F3 springs
Bosch starter
Camber shims
Bellville washers
Chassis - specific hardware
Bosch Motorsport sparkplugs – new
Factory manual (an amazing engineering document)
Complete parts drawings/list
[SIZE=2]F/R Pushrod turnbuckle with rodend
Rear suspension clevice: new
Transaxle bearings: new
AP Clutch discs: 2 at .098" thickness
Fuel and oil filters: new
Alternator belt - new
Caliper seals - new
[/SIZE]
Motor:
A complete, brand new, dyno time-only Bertils USF3 VW engine is also available: It is compete with structural pan and valve cover, Bertils/TDC pump, billet front cover, fuel injection manifold, butterflies, injectors, linkage, engine harness, etc...Everything is brand new. Unitized container included
Located at Buttonwillow Raceway, Southern CA
Pricing:
Car with low time motor: Fully sorted and ready to run - 38.5k
Spares: 7.5k
Brand New Motor: 11.5k
Prefer to sell as a package: offers considered.
[/SIZE][SIZE=2]michael.scully@designworksusa.com[/SIZE]
[SIZE=2]805.376.6246
[/SIZE]
