Page 1 of 2 12 LastLast
Results 1 to 40 of 57
    Administrator dc's Avatar
    Chicagoland, Illinois
    Liked: 1417
    Default rFactor League Race #4: Road Atlanta
    If anyone is looking for the track because they are getting a mismatch with last year's track, it's a new version (beta): HERE
    Keith needs to tell everyone these things.
    Contributing Member Jerry Santucci 33's Avatar
    Aliquippa, Pa.
    Default thanks doug.......
    Keith was probably tied up doing interviews after the big win
    Seeeeeeeeeeeeee Ya --- Jer
    "Use to be" --- CF #33
    Liked: 1417
    Is anyone else getting ANY Road Atlanta track to work? I get booted with a mismatch every time, no matter what version I install. And the sky is an Escher painting, too.
    Senior Member Gokart Mozart's Avatar
    Wauwatosa, Wisconsin
    Liked: 129
    Gents,
    Here are the points standings after race #3 at Mosport. Things have shaken up a bit.
    Let me know which Road Atlanta to download!
    Cheers,
    JD
    Jacques N. Dresang
    Kettle Moraine Preservation & Restoration
    1977 All American Racers Eagle DGF #005
    1972 Elden Mk10B AM73-49 - #140/1
    Lurker Keith Carter's Avatar
    My Desk
    Liked: 447
    The latest Beta for Road Atlanta should be used. You need to keep the "Road Atlanta" folder in the mix so your directory structure should be:
    Locations\RoadAtlanta\Road_Atlanta2007\.....
    I didn't have a chance to do a test lap install due to an angry wife and two screaming kids. I'll try to get on tonight to confirm I can connect.
    2003 VanDiemen FSCCA #29
    Liked: 129
    I downloaded it over lunch and it crashes when I go to load it every time. Perhaps the BETA isn't quite kosher yet?
    Jacques N. Dresang
    Liked: 1417
    I got it to run, only with no sky and it won't allow log-on to the server.
    I'm going to see if I can find a ZIP version of the RA that we ran last year—at least that one worked for everyone.
    Contributing Member DonArm's Avatar
    Indy/Orlando
    Liked: 6
    i was able to run a few laps today with no problems with the older version.
    Liked: 1417
    Online or offline?
    The old version shouldn't let you log onto the server, unless Keith installed the wrong track on the server.
    My Desk
    Liked: 447
    I'll check it when I get home.
    Senior Member TrackBrat's Avatar
    Skokie, IL
    Liked: 33
    I don't even have the old version. I always found it interesting wtih the rfcentral website that the track is linked to...it has a picture of the last turn of Laguna Seca.
    Chris Buccola track brat since 1986.
    Chicago Region- Corner Worker
    Spec Racer Ford Gen 2 #38
    My Desk
    Liked: 447
    Try it now. It appears the two links on rfc are different. Use the top link.
    Liked: 1417
    Too much confusion here and on the rFc board. I'm downloading the BETA version and uploading it to the ApexSpeed sever for anyone to grab the correct version. Find the correct version HERE.
    I'm not going to run online with the detail set on MAX, so does anyone have a link to the former SCN file that was on the now defunct race sim central?
    My Desk
    Liked: 447
    To make sure you have the most recent version. Use the one that has the GDB file from October 2007.
    Indy/Orlando
    Liked: 6
    online and it let me log in. Check the hotlap page it recorded my run.
    My Desk
    Liked: 447
    Try it again, Don. The one that was on earlier was the older version that is still linked on rFactorCentral (the bottom link). The newer version is on the server now. The GDB file in the track folder has a date of October 2007.
    My Desk
    Liked: 447
    You can now get the same version the server has HERE
    Indy/Orlando
    Liked: 6
    ok, now I can't get on
    Since I have the old track in the game, can I just load the new track and then will it overwrite the old one? Or do I need to delete the old track from the game and then add the new one?
    My Desk
    Liked: 447
    Try it and see what happens. I typically like to delete the old track and then dump the new track in the folder, but overwriting the old track should work ok. If you have any issues, I'd delete and then copy it over though.
    Indy/Orlando
    Liked: 6
    Keith,
    PLEASE go back to the old track !!! The Sky s;!ks on the new track. It's very very distracting!
    Liked: 1417
    The problem is, the old track isn't available online anywhere anymore for some reason.
    I love Road Atlanta in rFactor, but this is a mess. I think we're going to have to post all of the fixes here on ApexSpeed, otherwise, this isn't going to work.
    My Desk
    Liked: 447
    I don't have any issue with the track. Is it zebra striped?
    Liked: 1417
    Yeah, the zebra striped sky is fixed by jacking up the detail levels on your settings, but that's not gonna fly for me for league racing. There is another fix, but the files needed are on sites currently not in existence anymore.
    This needs to get worked out soon, or we need to postpone Road Atlanta until these things can get sorted out.
    Contributing Member Tifosi's Avatar
    Janesville WI
    Liked: 25
    What's the file name of the old track? I probably have it somewhere.
    Dave
    My Desk
    Liked: 447
    Do any of you still have Road Atlanta from last year? Try copying the SCN folder into the new RoadAtlanta folder (rename the original one). I can't troubleshoot since I don't have the problem.
    It seems like we had the same issue last year with the SRF league:
    http://www.trackpedia.com/forums/showthread.php?t=4835
    Liked: 1417
    I found the file to fix the sky, and the fix works. I was just on the server, and the sky is fine.
    Download THIS and install it in your Road Atlanta 2007 folder, writing over the old SCN file that is in there now.
  27. #27
    Indy/Orlando
    Liked: 6
    Thanks !!!
  28. #28
    Liked: 1417
    Road Atlanta track map...
  29. #29
    Indy/Orlando
    Liked: 6
    Default Cameron
    sorry wasn't being anti-social, the chat is not working for some reason.
    Anyone have a suggestion?
    Indy/Orlando
    Liked: 6
    Still having problems with the chat. Message center in settings is turned on. The only thing different that I've done is remove the old scn file and insert the one Keith posted and download the skins package.
    Any suggestions?
  31. #31
    Skokie, IL
    Liked: 33
    Maybe you have the chat disabled when you are driving. or could have that window hidden. I forgot what number the chat window is.
  32. #32
    Contributing Member JHandley's Avatar
    West Unity, OH
    heya guys, is the server down?
    I just tried to log in but when i enter the server address it shows not available?
    Jeff Handley
    Reynard 84sF
    cainesgrandad@yahoo.com · www.reynardowners.com
    "Luck is when preparation meets opportunity."Roger Penske
  33. #33
    My Desk
    Liked: 447
    Try it now. The server app shut down for some reason. I'm not sure when it happened.
  34. #34
    West Unity, OH
    K, will do Keith.
    Thanx
    Jeff Handley
    Reynard 84sF
  35. #35
    West Unity, OH
    That did it, Thanx man.
    Jeff Handley
    Reynard 84sF
  36. #36
    Indy/Orlando
    Liked: 6
    Anyone else having problems logging onto the server? I tried to do some laps this evening and it said "game not found"
    Started up rfactor, clicked on join, clicked on the blue + at top the link to the server showed up, clicked accept and the message "game not found came up.
    Late reply, ignore
  37. #37
    Indy/Orlando
    Liked: 6
    Still no chat. Does anyone have any suggestions? I've tried clicking on the chat button while in the game. I've checked all of my settings still nothing.
    Don
  38. #38
    My Desk
    Liked: 447
    Has chat worked before with other tracks? I've never head of an issue like no chat before. Chatting is overrated anyway.
  39. #39
    Indy/Orlando
    Liked: 6
    Yep, it worked when I was running some laps at Mosport. I didn't get a chance to try it on the other 2.
    I don't need to chat but, like last night when I was running and Cameron BLEW by me on the back straight he was able to suggest a little less wing
    Anybody interested in sharing their setup ?
  40. #40
    Liked: 129
    Don,
    I'm miles behind the Carter boys, but I've been running in the low 1:18's with this setup.
    Cheers!
    Jacques N. Dresang
