I know my car isn't an FB, but y'all are the closest thing to my FB lite , so here goes.
I am thinking of building wings out of styrofoam-like material and then having them sprayed with truck bed-liner material. I remember an ad where Line-x sprayed a styrofoam cooler with material and then someone could stand on it. So the material is pretty strong but should be light weight in a thin coat. I don't have the bucks for a one-off carbon fiber wing, and don't want to hassle with aluminum, hence the foam idea.
The mounting points would be adhered to the foam prior to spraying. I would probably put two aluminum tubes through the foam to act as spars and provide mounting points for the aluminum end plates.
Am I nuts?
