Results 1 to 24 of 24
Thread: Car Weights
    Phoenix, AZ USA
    Default Car Weights
    I've been meaning to post this thread for a while now. Some recent rumors of top speeds at the June Sprints prompted me to finally do it...I was trying to figure out how a car that was 5mph slower through the corners and has at least 10% more frontal area could be 5mph faster on the straights? Can't be the engine...they both have the same "stock" motor according to the rules....right?? Maybe its weight....that's the only other possiblility....So....
    What weight is your F1000 car when it goes across the scales after a race?
    And be honest....
    For example, my car (prototype) came through the scales at FIR in March at 1,023#, but I have 18 pounds of lead on the floor pan under the header...so a true weight would be 1,005#. We didn't check the fuel remaining. I weighed around 165#. Truthfully, I've just been too lazy to take the lead out....it is a pain to get to it....I'll do it while we're rebuilding the car this summer.
    When Scott Dick won the January National race here in Phoenix he weighed 1,007#...no lead...and from memory...3 gallons of fuel in the car. I don't remember how much Scott weighed...pretty close to my weight I'd guess.
    Matt Conrad
    Phoenix Race Works, LLC
    Liked: 3787
    Ceramic bearings...
    stretched hub bearing seals...
    increased tire pressure...
    low grip tires, for freer top end...
    no toe alignment...
    gearing...
    careful attention to brake pads releasing from the rotors...
    wing angles...
    radiators that "breathe" easier...
    I can think of a LOT of reasons.
    Always at Road America you give up corner speed for top end.
    Ridgecrest, Ca
    Liked: 259
    to Frog's list add inertia (rotational), viscosity, and Cd.......
    less wing would translate into lower Cd and less grip (cornering speed) which is consistent with your observations
    Art
    artesmith@earthlink.net
    Phoenix, AZ USA
    I'm really looking for weights on the current F1000 cars....I was being a bit sarcasctic on the radar gun data...
    Matt Conrad
    Las Cruces, New Mexico
    Phoenix F1K-07 F1000
    I have weighed in consistantly at 1072-1075 #'s
    This was the last 11 race events.
    Suspect after race...... the car has 3 to 4 gallons of gas left in the tank. It is an 8 gallon tank.
    Richard Dziak
    email: sonewmexico@gmail.com
    Auburn, GA
    '07 Cooper Elan
    5 gallons of fuel (30lbs approx) and me onboard = 1020lbs.
    The car is pretty much pared down, and I don't think I can loose much more from my 150lbs body! Winter project is to take molds off the bodywork and make pre-preg parts which should get me under 1000lbs (the stock VD bodywork is very heavy.) For what it's worth 140mph at Road Atlanta with a rear gear that was a little too tall, so maybe a few mph there?
    Ben
    atlanta, ga
    Liked: 136
    Default Whey, way, weigh...
    1029 post race at Sprints, including driver / approx 160lbs, and very heavy engine cover, which will hopefully soon be replaced, saving possibly 20 lbs.
    Started race w/ full fuel cell (to brim), as I needed some insurance to be over 1000 lbs.
    Not sure how much fuel was used, guess I'll have to top it off and see how much it takes.
    I believe I was 1007 at Rd Atl the other day w/ 1 gallon in the cell, again w/ me in car.
    Your question was how much does the car weigh after the race, so although I've given some #'s to digest (Buuuuuuuuurp), I guess it's better than nothing...
    GC
    Atlanta, Ga
    1015-1030 depending on the track.I always go out w/ a full tank and could possibly save some weight there.
    Sean O'Connell
    1996 RF96 FC
    1996 RF96 FB
    2004 Mygale SJ04 Zetec
    Default top speed rumors?
    What were the top speed rumors. I did not hear anything?
    Thanks ... Jay
    Top speed at Firebird International Raceway, Phoenix Arizona with 1072 #'s in car .......139 MPH.
    Richard Dziak
    Atlanta, Ga
    My stock dash says I'm doing 180+ mph Too bad I'm not running the stock gear ratios or tire sizes.
    I hit redline in 6th at Road Atlanta going down the hill into 10a with a 15-43, so that should be 152.
    Sean O'Connell
    1996 RF96 FC
    1996 RF96 FB
    I was wondering the same thing. Too hard to guess with 4 different FB chassis there (except we can rule out the Piper as being 10% bigger than anything else, right? :-).
    PS. My top speed was 153. I didn't actually measure it, but I'm basing that on Sean going 152. :-).
    Phoenix, AZ USA
    I just had read in another thread that someone clocked the fastest straightaway speed on one of the Stohr cars was 150mph and that car was 5mph faster than the Piper....while the Piper was carrying 5mph more speed through the corners....seemed logically backwards to me, especially when reports back in November showed the Piper at Road Atlanta to be the fastest straight line car....by a ways. I would assume the set-ups for these two tracks to be pretty similar?
    Glen. WOW....that must be one heavy cover if you're going to lose 20 lbs! FYI....we get about 10mpg while racing (obviously depends on yellows, etc).
    Richard's Phoenix has some extra ballast....he's around 6'3" tall....and from memory....we used 225 lbs of lead when we put his car on the pad to do the set-up.
    Matt Conrad
    Atlanta, Ga
    I think the Piper was down on power (or having some other issue)... but still had a great pilot. That would explain the higher cornering speeds but slower straight line speeds.
    Sean O'Connell
    1996 RF96 FC
    1996 RF96 FB
    Atlanta, Ga
    Seems like that big head of yours would create too much drag...
    Sean O'Connell
    1996 RF96 FC
    1996 RF96 FB
    Senior Member jjstecher's Avatar
    New York City
    1072lbs after the Sprints with me being fricking 230lbs and 2.2 gallons of fuel in the car. So I need to lose lets see one leg, half my brain and an arm to get down to Glenn's weight (wife already has my nuts). Seriously through by next year it will be 200 but I can't go lower than that at 6'3" so its got to come out of the car. My fricking bead seat weights 15lbs some how...
    I am not sure what apex speeds your talking about Matt but I have speeds from the carousel courtesy of some friends and the Stohrs were 4-6mph faster there than the other FB's. I also don't see how the piper would have more mechanical grip either though the slower turns...I would say that Justin might be making up for the lack of mechanical grip and thus was faster but I am guessing.
    Max I hit on the GPS was 145 into T5 up from 140 two weeks ago when i was in the car for the first time really.
    Senior Member VehDyn's Avatar
    Texas
    With respect to the ARRC, I believe the Piper had a 2007 GSXR whereas Cole and Jean Luc were using 2006 motors.
    Were those speeds taken during the race? Its hard to believe Justin was down on power when he was setting those great times in qualy. He is a great driver though and pretty familiar with a Piper. What actually happened in the race?
    Ken
    Phoenix, AZ USA
    What I'm seeing though is that most cars are going to be within 25lbs of the minimum when there's a 165-175# driver. Obviously you guys that shop at the Big & Tall stores are going to have a bit of a weight penalty.
    Another factor at these large tracks might be the tire sizes...I'm assuming the Stohr guys are still running the 8's and 10's...and I've seen the Piper and most of the VD conversions running the narrower 7's and 9's. Personally, I've found on the shorter, tighter tracks that those wider tires do seem to provide more grip...I just don't know how much of an aero penalty they impose when the track is like RA.
    Matt Conrad
    New York City
    Ken I find it hard to believe the Piper was only doing 145 as well as I know for a fact on one lap in quali he drafted up on me and past me on the front straight and on that lap on data on GPS I was at 141 at breaking for T1 which is about 3-4mph off T5 entry speed. I am calling sandbagging if someone is saying that car or Coops car were only doing 145 max (jesus I was leaving time on the track left and right and was hitting 145 with a ebay motor that I just bolted in. I think at the end of the day there is not as much in it as everyone things aero wise between the VD's, Piper and the Stohrs.
    Matt - Yep all you little bastards out there running around will all be damn close to the 1000lb mark. Its a shame superior genetics have lead me to be bigger. :P Or it could be the damn twinkies.
    Surrey, BC Canada
    Matt
    I was the one who posted seeing speeds in excess of 150mph, in my 2008 Stohr.
    This was from my GPS from my CDS data system, also going into T5 at Road America.
    We were using a bone stock 2007 engine bought from George Dean, running on 93 octane pump gas from the gas station in Elkhart Lake.
    We saw these speeds all weekend and were not in a draft.
    We weighted 1030 at the end of the race with there (RA tech) scales. I weigh 170, and only had 1 gallon left at the end of the race.
    We will dropping weight in the car for the ARRC race to be as close to 1000 as we can get, heck maybe i will shave the rear wings down 2-3mm to help with that.
    Cheers
    Kyle
    atlanta, ga
    Liked: 136
    Default Cover Heavy, Ugh
    Matt, Seriously, the cover is really heavy, also we run 6 and 8" wheels.
    I've no idea of speed at Rd Am; no wheel speed sensor.
    Bone stock, new '07 Suzi.
    GC
    PS, I've got a set of 8's and 10's to put on for Barber!
    Atlanta, Ga
    Coop-
    Tell me more about the air box on your car....
    Sean O'Connell
    1996 RF96 FC
    1996 RF96 FB
    atlanta, ga
    Liked: 136
    Default Boxe D'Air
    Sean, It's one of the kits available from Piontek Engineering, who manufactured the Novak kit It's offered seperately, or, as I did, part of the whole shebang. It's very lightweight, utilizes a cone filter that's located between the 2 pieces that slip fit together.
    It's a bolt-on for '98 and later VD's...
    GC
    Vancouver, Canada
    Default Stohr F1000..
    At the ARRC race in 2007 with only half the data sensors in the car that I have now,
    + a full minidv camera system which added an extra 4 - 5 lbs extra that could have been removed
    My car was virtually bone stock STOHR factory trim aside from the data system and camera system I came accross the scales at 1004 lbs. with .5 lbs of fuel left.. on the last lap my fuel pressure warning light was coming on the dash on cornering.
    I dont remember what weight I was for that race.. I know I spent alot of time working on the car prior and less time eating.. so I was on a not so preffered weight loss program at the time.
    Nicholas Belling
    email@nicholasbelling.com
