Yamaha has a cool quick disconnect on the fuel line going into the injectors. I would like to retain that when I run my fuel line. But I'm used to carbs with 3 psi. With 45 psi, I want to be sure I have a secure connection at that point. Can I just clamp the new line over that fitting? The existing set up looks like that joint is tubing within tubing and crimped or heat shrunk all together.
Would be helpful to know how others have dealt with that and TIA.
Billy
