Results 1 to 10 of 10
    San Leandro, CA
    Default fuel cell damage from exhaust heat
    Wayne at Stohr just sent out an advisory to all of the Stohr F1000 owners pointing out that in some high temp situations they have found some heat damage to the back side of fuel cell bladder due to high temperature. The fuel cell, like many formula cars I suspect, is located under the drivers seat, separated from the engine area by an aluminum bulkhead.
    We will be adding insulation in that area on our Stohr, but I'm bringing it up here in case it might be an issue with the Van Dieman conversions, since the fuel cell is in the same general vicinity, as is the GSXR exhaust header.
    Marty
    Marty Bose - #1 gopher, GonMad Racing
    Atlanta, Ga
    Thanks for the tip.
    For some reason we have not seen the heat that Stohr owners have been dealing with. My cel (despite the fire) looks like new. I will be adding aluminum heat barriers to the firewall to help keep the fuel cooler...
    Sean O'Connell
    1996 RF96 FC
    1996 RF96 FB
    2004 Mygale SJ04 Zetec
    Thanks, Marty. In my conversion, that has been a hot area. Silly motorcyle engines that should have their exhaust out back (I know, I know).
    I'm hoping that a ceramic coated header, heat shields and directed air flow will be enough to keep the temperature tolerable.
    Maybe I should add a fuel cell temp sensor, too! :-).
    Senior Member Tom Sprecher's Avatar
    Living race car free
    At the rate you guys have had rods punch holes through crankcases in that area and start fires some type of shield should be used and a good one at that.
    Tom Sprecher
    ATL Region Treasurer
    Quote Originally Posted by Tom Sprecher View Post
    You rotary guys just think throwing rods is so funny, don't you? :-).
    Atlanta, Ga
    People love to talk about things they don't have... in Tom's case, a rod.
    Sean O'Connell
    1996 RF96 FC
    1996 RF96 FB
    decatur, GA
    Default Tom, they like you, really..
    You know you are well liked when they kid you like this!
    Rods? We don't need no stinkin' rods. Vamos!
    Tom Sprecher
    Senior Member jjstecher's Avatar
    New York City
    So your saying basically that the heat reflective gold foil tape isn't enough to keep the temperatures down? On my Stohr DSR I never really found that once I added that tape there was any issue with heat in that area.
    I am curious if you Stohr was getting the fuel cell melting to the metal bulkhead or what.
    Pittsboro IN
    Liked: 282
    Not all gold foil is created equal. Could this be part of the problem?
