OK here is the situation. I am thinking about going for a new distributor on the motor. So lets start with the set up of how I got here. After a winter rebuild & alot of work, we ended up with a fresh motor that we had sent the carbs out to be rebuilt & changed the distributor out from a fomoco point to a bosch with the pertroniks electronic ignition. The first weekend out with the fresh motor we couldnt get the motor timed. Step one, change back to the points in the bosch. Still the timing was all over the place. OK maybe the distributor we "inherited" was faulty. So we borrow a fomoco with points. That goes in & my timing light craps out (we think) but not suprising, i have had it for a million years. So we borrow another timing light & still no trigger to the light (Hmmmm maybe mine isnt broken after all) So we pull a couple of plugs to find the number one plug so fouled that it wasnt firing, ergo no trigger to the timing light. It seems that the gentleman who refreshed our carburators this winter jetted them way too rich. A quick jet change & BAM!! the timing dials in perfectly!!! Now with all that said. Here is what i have 1) a Bosch distributor that seems to be in decent shape with set up for electronic ignition or points. 2) a fomoco distributor that i believe is fairly new with a set of points. So now what I am looking for is suggestion as to what I am looking for in looking over these distributors to decide if i use one over the other or if I go for a new one & if I go new, I know i want electron ignition but do i go fomoco or bosch?
