Home
ApexSpeed Portal HomeApexSpeed Reader GalleryApexSpeed.blogsApexSpeed AdvertisingForums
Old October 30th, 2003, 1:48 PM   #1
Jim Garry
Jim Garry's Avatar
Post
I plan on painting my gray wheels gold. They are Minilites and so the rim part of the wheel will remain chrome and the spokes will go from gray to gold.
Any tips on prep and type of paint would be appreciated.
__________________
Jim Garry is offline   Reply With Quote
Old October 30th, 2003, 2:24 PM   #2
JAC
Post
You really only need to have a proper primer for the metal. Check with a shop.
I painted my steel wheels and after a friend said I should have added the flex additive for plastic parts to prevent chipping. I think he was right.
__________________
Merlyn Driver - MK17 FF
JAC is offline   Reply With Quote
Old October 30th, 2003, 7:46 PM   #3
Bill Hetzel
Bill Hetzel's Avatar
Post
I agree that proper primer is a good idea in most cases. I paint my own bodywork and use PPG primer and urethane with hardner. But for my wheels, I took the easy route. I washed the Panasports with Simple Green, taped up the silver rims and shot the gold paint out of a can. It took about a half hour and the wheels haven't chipped thru 4 races.
The best thing is the paint cost me $1.50.
Wal-Mart has 3 different shades of gold metalic that comes in a small size spray can for $1.50.
The can will do one coat on 4 wheels. If they chip, I'll just spray them again.
__________________
Bill Hetzel
Bill Hetzel is offline   Reply With Quote
Old October 31st, 2003, 8:23 AM   #4
rustyracer
Post
Go to a NAPA(or similar) and get a self etching primer. This will adhere to the alloy surface of previous paint finish and is very tough. Your new paint will have a great bond. Adding a flex agent is correct if you are using a base/clear system. But finish with a good urethane clear coat and you should be all set!
Cheers
rustyracer is offline   Reply With Quote
Old October 31st, 2003, 9:45 AM   #5
Jim Garry
Jim Garry's Avatar
Post
Thanks guys. Much appreciated.
__________________
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
©ApexSpeed 2000-2013
